01-08-2009 | #1 |
Shift Light
I have been thinking about installing a shift light. Don't know too much about them and the ones that I have run accross come with a tachometer. Don't think I need the tach but would like just a light. Any ideas?? Also, anything about mounting areas and if they are a difficult installation. Thanks
01-08-2009 | #2 |
Re: Shift Light
I dont know much about them but I saw an led shift light on the CF last night in the for sale section from a vendor. It looks like it can be preset for a specific user.
http://forums.*************.com/c4-p...-ky-speed.html
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-08-2009 at 10:49 PM. |
01-08-2009 | #3 | |
Re: Shift Light
Correct the Raptor is a great Shift light pete and a couple others have it, but theirs is the single stage not dual stage I have a harlan shift light I had in my 89, I was going to install it in my 90, but not sure when I will get to it
01-09-2009 | #4 |
Re: Shift Light
01-09-2009 | #5 |
Re: Shift Light
I have an Autometer standalone shift light that has multiple LEDs & digital display for RPM's. The base uses a nice ball & socket type system for adjustment. Its programmable & has progressive shift lighting. They are really nice and easy to instal. I highly recommend it, especially if your oem tach is no longer what it used to be. I mounted mine dead in front of my face on the steering column. Auto meter makes a couple different versions, some fancier, some cheaper. I think the $$ one has datalogging function or something. You may want to look into it. "Digital Shift Light" from Autometer.
01-09-2009 | #6 |
Re: Shift Light
Thanks for the information guys. I will look into your suggestions
01-10-2009 | #7 |
Re: Shift Light
Where is the best place to pick up the engine rpm signal for one of these?
01-10-2009 | #8 |
Re: Shift Light
probably off the tach line in the car
01-10-2009 | #9 |
Re: Shift Light
thought to throw this into the mix . i have a G-Tech pro rr it has a built in shift light that works off the cig lighter. don t have to hook any wires .plus once you get it dialed in gives you the ability to down load your runs onto the computor . you can learn alot about your runs with the supporting software, ie wheel spin starting line rpms shift rpms etc . it helps you adjust leave rpms and shift rpms for your best et . i found that i was shifting at too high an rpms . i short shift 1-2@6200 (no wheel spin) and shift 2-3 at 6900 and 3 -4 at 6500 by doing this i knocked .35 off my et .plus as a bonus you have a drag strip 24/7. it is accurate to within .05 on et and .75 on the mph
01-10-2009 | #10 |
Re: Shift Light
