Old 01-03-2009   #1
ZR1Vette
ZR1Vette's Avatar
Default Winter Projects One Year Later>>>
After I acquired my ZR-1 in December 2007, I embarked on the first round of winter projects starting in Jan 2008... this was the view for a couple months back then>>
Well, now one year later it is time for round two of winter projects so afamilar view>>
I had to replace the upper control arm (right side) due to a blown ball joint seal... in fact the entire seal was torn and smashed
Here is the old and new control arms>>
Job was really a lot easier than expected...the C4/ZR-1 shop manuals are really coming in handy...very specific torque specs required.
For anybody having to do this...just remove the center wheel well cover and strut actuator and you have easy access to the control arm nuts-to- frame and once removed control arm easily removes>>
Next job was to switch out brake pads and rotors... in last year's winter projects I installed EBC ceramic pads and EBC sport rotors.. well, I just did not like the feel so went back to OEM rotors (zinc coated) and my pads of choice- Porterfield R4S..
Next project are injectors etc....Phil and Dave have volunteered to come over and "hold my hand" being a newbie at removing the plenum. Also,decided to replace the tires... the GS-D3s are 7+ years old with very little mileage, but they are showing the aged induced hardening.
I think that is enough for this year's round ;-)
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 01-03-2009   #2
32valvZ
32valvZ's Avatar
Default Re: Winter Projects One Year Later>>>
Great pics
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 01-03-2009   #3
Jagdpanzer
Jagdpanzer's Avatar
Michael
Hate having to be to one to break it to you pal, but the finish on your exhaust pipe just before it connects to muffler is starting to dull a little.
Otherwise it's looking fabulous.
Old 01-03-2009   #4
RedSled
Looks good as always Michael!
- Keith '90 Red/Red #1383
RedSled is offline   Reply With Quote
Old 01-04-2009   #5
Aurora40
Aurora40's Avatar
Looks good! Any idea how that happened with the balljoint? Let me know if you need any help with the injectors, though it sounds like you've got it covered.
Bob Saveland
Former owner of #2517
Old 01-04-2009   #6
HIZNHRZ
Michael, car looks great as usual. I'm wondering if I could invite myself over to watch changing out your injectors. I've been under my plenum twice now, once with help and once solo, and the process is still not something that I'm confident with. I figure the more I either do it or watch it happening the better.
Old 01-04-2009   #7
ZR1Vette
ZR1Vette's Avatar
The cotter pin for the slotted upper control arm ball stud had clear evidence of being removed and reinstalled....not sure why, but clearly the reason for the ball joint grease cover failure was whoever did the work way over torqued the nut (spec is 33 flbs and bet the nut was somewhere north of 60 flbs) and caused the cover to fail.
Since the new control arm install will be interesting to see if alignment is still correct (used the same number and in same locations alignment shims).
Michael
:cheers:
Old 01-04-2009   #8
ZR1Vette
ZR1Vette's Avatar
Absolutely invited...in fact the more the merrier... make it another ZR-1 gathering (I will supply food and drink)... just need to lock in a date...looks like sometime soon after Jan 17 (Maryland ZR-1 gathering)
Michael
:cheers:
Old 01-05-2009   #9
Jan 18th? Or the next weekend?
Old 01-06-2009   #10
Man that car is soooo cherry!
Kind of doing the same project....sort of, 4 new arms from corvette recycling. I figure that while I'm in the neighborhood I should do the bar ends & mounts, outter tie rod ends and the rack mounts....figure OEM parts for that stuff too; any opinions on that choice? I was thinking poly stuff...I don't feel like taking apart the new arms to toss new bushings in the can......too cheap...
My b-joint & tie-rod covers came blown up as std equipment. I let'em live on borrowed time long enough. I figured that someone tried to grease'em without hanging the front end...just lazy I guess?
The plenum pull is a nice excersise to do as it lets ya see all our stuff & how it all "connects". I came away with a better understanding....I'm a muscle memory type learner......one thing...a long torx set, T-15(?) or a pack of three at sears or autozone for the plenum. The outside plenum bolt on the even bank @ the fire wall (last bolt so to speak right below the fuel line block?). Loosen the 2 bolts in that block enough so you can swivel the fuel lines or you may not get a good seat with the torx bit on that last rear plenum bolt....my fuel lines were in the way & the torx went on cocked.
