09-26-2008 | #1 |
LT-5 Engine Weight
I am picking up my shortblock today. Anyone know the weight of an LT5 engine, I am going to get an engine stand, and noticed there are 750lb and 1000lb stands. I assume I need the larger of the two.
LGAFF 92 ZR1 #234 |
09-26-2008 | #2 |
Re: LT-5 Engine Weight
If it was me reguardless I would buy the heavier stand you never know what the next project may be
09-26-2008 | #3 |
GOLD,
MODERATOR !!? woow Congrat! Thanks Hadi.. Last edited by GOLDCYLON; 09-26-2008 at 10:07 AM. |
09-26-2008 | #4 |
Goldcylcon/moderator=inmmates running the asylum.
LGAFF 92 ZR1 #234 Damn straight now get back into line prisoner #346792 or you know whats good for you lol |
09-26-2008 | #5 |
750 lb will work but it IS a heavy SOB. Maybe the bigger one will give piece of mind. I get nervous just turning a sbc on one, lot of weight hanging there.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
09-26-2008 | #6 |
You guy's know what MODERATOR means ?.......We have to be nice to Daryll now Congrats Daryll , Big Thanks for helping out !! 00000000000000000000000000000000000000000000000000 000000000000000000000 Go with the 1K stand. Much safer.
09-26-2008 | #7 |
Short block should still weigh between 300 and 350.
And once you start adding the heads, cams and other stuff, the weight goes up pretty quick. This is the stand I use. NAPA NLE7915070 |
09-26-2008 | #8 | |
That's a good stand! I like the gear crank to rotate the engine. The LT5 is top heavy. Rotating a complete engine without the crank is a real ordeal. You can hold it back going pan up, but to rotate it back upright is a bitch! I did it once by hand, barely. With no help, I since use a cherry picker to rotate back upright. The other issue..... NEVER own a 3 wheel engine stand, only the 4 wheel like above.
09-26-2008 | #9 |
That is a sweet looking stand. And I also agree the 4 legs are the way to go.
09-26-2008 | #10 |
Got the 1000lber, picked up the block and its in my garage.
LGAFF 92 ZR1 #234 |
