06-24-2008 | #1 |
Code 55 Lean Condition at WOT
Took the car out after installing the new NGKs. Part throttle is very nice and idle is much smoother. Trying a blast at WOT, I got an SES which was a Code 55. This was a hard code which didn't drop with driving as it had done previously. I went out once again, this time with the scantool. Here's the part of the scan where the Code 55 was set. It happened at the top of the rpm band. I've checked FP and that seems to check out. Also, secondary port throttle is not the cause here.
Any observations are welcome. |
06-24-2008 | #2 |
Re: Code 55 Lean Condition at WOT
Swap back to your old plugs that you just removed and see fi the Lean condition goes away..
06-24-2008 | #3 |
Jeff,
I'm going to take the NGKs and re-gap them to .035-.040, but looking at the scan, something causes the injectors to drop PW. At the same time, the timing goes to 14.1d. My theory is that something happened to cause the injectors to drop PW which then caused the Lean condition with the code 55. This all happened at a point on the rpm range where the Fuel Kill was set, 7175rpm. Just a thought. |
06-24-2008 | #4 |
so set the Fuel kill to 7225.. see if that helps too.. but worst case, go back to the old plugs cause at WOT you had no issues
06-24-2008 | #5 | |
06-24-2008 | #6 |
Why does your speed drop from 90mph to 77mph within one frame? It seems weird the line you highlighted as the code setting, because that's when the throttle is closed. Or does that hightlighted line not really signify that?
I can't tell if that one column is R O2 volts, but maybe it is, looks like it goes from .9ish to < .1ish That would certainly seem to indicate a lean condition. FWIW, I've tapped the limiter several times in my car and it's never set a lean code.
06-24-2008 | #7 |
A40,
The Vehicle Speed is in kph. But its still a drop of 8mph or so during an upshift. I was fighting the ASR also. Didn't turn that off which I should have. I wouldn't think Fuel Kill would cause a lean condition but right now looking at all options. |
06-24-2008 | #8 |
Dom,
pulse widths are in cols. Q & V. Your secondary injectors shut off, it looks like to me. What does your PT Closed spark advance look like? About 20d at high RPM & Load (14.1+6)? Notice also the pulsewidths have obviously changed after the shift to the PT Closed map, as they never recover to the 23ms range as before the shift. Todd |
06-24-2008 | #9 |
Todd,
Exactly. Actually, Closed Throttle SA is set to 16. My suspicion is that the injectors shutdown because of the DRPs. With the injectors shutdown, I got a code 55 which closed the Port Throttle. Question is what happened to the timing there? Car runs fine otherwise. Thanks for your help. Maybe there's something in the logic you could find. |
06-24-2008 | #10 | ||
What have you done with the secondary vacuum sensor? If I remember, you have removed the port throttles. Any other mechanical modifications to the port throttle system? Quote:
Todd |
