Old 06-19-2008   #1
Default Would these studs work with 18mm spacer??
Heat-treated 8740 chrome moly studs have a tensile strength of 190,000 psi to handle the shock loads and lateral forces in racing applications. Pack of 5 studs. Lug nuts are sold separately.
  • Knurl Diameter: 0.509"
  • Knurl Length: 0.315"
  • Nose (unthreaded) Length: none
  • Shank Length: 2.500"
  • Thread Size: M12x1.5
These are 63.5mm long vs 68 for the GM 22551491.
Thoughts?
Thanks
92 ZR1
#234
Old 06-19-2008   #2
Default Re: Would these studs work with 18mm spacer??
Late F-Body, Corvette (Short)0.509"0.315"2.185"none2.500"M12x1.5
Looks like threads are 2.185"
92 ZR1
#234
Old 06-19-2008   #3
WVZR-1
You decided to try 18mm spacers?
Measure the backside of the wheel through the wheel to the deepest point of the taper(wheel nut seat), add 18mm for spacer and it looks like you need 18mm to extend "just beyond" the threads of the OE nut. ONLY JUST BEYOND THE THREADS! I believe the aircraft standard is three full threads beyond, that would require something at 23-24mm. (1.5 pitch x 3)
Old 06-19-2008   #4
bring a wheel to my house, we can bolt it up tot he rear with my 20mm spacer to see if you like it..
