Old 06-14-2008   #1
QB93Z
QB93Z's Avatar
Question How much HP gain by removing cats?
I attended an event called Vintage Thunder - A Day at the Races put on by the Mason Dixon Chapter of NCRS. It was held at Cecil County Dragway in North Eastern Maryland. We spent the morning making time trial 1/4 mile runs and then had a single-elimination bracket race in the afternoon.
I had the only ZR-1 there. The crowd was mostly C5 and C6, but there were a few olders Corvettes as well.
The event was very well run. Thanks to the Mason Dixon Chapter of NCRS for putting it on.
This was my second outing at the drag strip running my 1993 ZR-1. This time was different because I removed my catalytic converters. The change in performance was dramatic compared to last month in Beech Bend. (Not my performance, the car's. My 60 foot times still suck.)
My best run run was a 12.9 at 112.8 mph. My best top speed was 115.7 mph.
The average ET improved .13 seconds and the average top speed went up by 4.1 mph (109.78 to 113.87).
I have a stock LT5 with headers, 4.10 rear end and a Corsa exhaust.
Removing the cats did not improve my 60 foot times at all. No surprise there!
In the past I have seen a comparision of the HP needed to change quarter-mile top speed. Can anyone estimate the HP gain I got by removing the cats?
Thanks,
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 06-15-2008   #2
Pete
Pete's Avatar
Default Re: How much HP gain by removing cats?
Jim 4MPH is about 50-60hp my opinion i don't think just CATS alone will give you 50-60HP unless you had bad CATS.
You have to make sure you didn't change your driving habits,i.e. shift points (rpm),power shift,tire slip at shift points,etc.
Also what is the elavation at Maryland over BG? i think BG is 600 or 700ft above sea level.
The other thing that comes to mind compare the timeslips from one run to another if you have a better 60ft you will get better MPH.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-15-2008   #3
flyin ryan
flyin ryan's Avatar
what's the altitude there?
Old 06-15-2008   #4
QB93Z
QB93Z's Avatar
The altitude at Cecil County Dragway is propably less than 75 feet, but I don't know for sure. The temperature was about 10 degrees hotter at Cecil County. (The temp printed on the time slips was 167 degrees, which is what it felt like in the car after 14 passes.)
I agree about the 60' times being a factor, but my average 60' time in Beech Bend was 2.275 and average 60' time in Cecil County was 2.277, essentially the same.
I might have improved my shifting but probably not much. I didn't try to change my technique.
Maybe Cecil County Dragway runs down hill.
I didn't change anything else on the car or engine since Beech Bend. I did wash it real well after driving home from Kentucky in the rain.
I recorded two of my runs on my laptop and at Cecil County the Knock Count was zero during the runs, so I was not getting and spark retard from that. At Beech Bend I didn't record the runs, but recorded the dyno runs that morning and got zero knock count also.
Old 06-15-2008   #5
GrayZ
Jim:
I asked Marc Haibeck the same question, when he was
refitting my corsa exhaust system.. I have Random tech
hi flow cats, he explained, 2 to 4 horsepower difference, W/o
but as Jeffvette expunged in a parking lot discussion,
not worth the smell.
GrayZ is offline   Reply With Quote
Old 06-15-2008   #6
flyin ryan
flyin ryan's Avatar
Originally Posted by QB93Z
after 14 passes
you got 14 passes in ONE day? WOW. we'd be lucky to get half that in a day. the times i posted for Craigs427 yesterday, he is right around the 2oh's 60'. 2.08-2.09 i think. i know Hammer has good 60's. hard to compare his car though, it's on another planet considering it's minimal changes.
Old 06-15-2008   #7
QB93Z
QB93Z's Avatar
I saw your other thread. Those are good times. I need to work on launching better. But, you know what, it is a hell of a lot of fun at any speed!
Old 06-15-2008   #8
QB93Z
QB93Z's Avatar
I think it has to be a track difference. It must be running down hill. If the track was short, the ET would improve but the top speed would be lower. Right?
This track follows NHRA rules, but I wonder if there is a certification of tracks that tells if the track is flat, level and the right length.
I guess it is like dynos, some just give higher numbers.
Old 06-15-2008   #9
flyin ryan
flyin ryan's Avatar
ya hard to say Jim. dyno & flowbenches are not uncommon to be different for a bunch of different reasons, tracks not so much but...again anythings possible. we're lucky in that we have an IHRA national event here annually in July so the IHRA crew go over everything with a fine tooth comb. speaking of down hill, NHRA allows 1' of elevation drop per 100' of length. so from start line to finish line, legally shouldn't be more than 13' lower at the top end.
