Old 06-07-2008   #1
Default These are gonna look ...
Test fit for spacers, thanks to Jeff for the spacer advice:
http://i134.photobucket.com/albums/q...f/DSC02462.jpg
http://i134.photobucket.com/albums/q...f/DSC02455.jpg
Should get the spacers on and these puppies mounted on tires sometime next week.
92 ZR1
#234
Old 06-07-2008   #2
Default Re: These are gonna look T*ts.
92 ZR1
#234
My god man finishing painting your Garage. Looks like your painting around all your tools and toys on the wall. It reminds me of a fat woman who no longers cares dress sizes and makes her own by just sewing around the edges. On another note clean wheels
Old 06-07-2008   #3
flyin ryan
flyin ryan's Avatar
are you going to attach the spacers to the wheels or leave them floating? you've come to far now to not do it properly, IMO. looks great BTW.
Old 06-08-2008   #4
U don't know half the story, I was out on a business trip for a week.....my mother came over to watch my daughter, she is a busy body and decided that I needed to paint the garage. However first she decided to redo all the drywall seams, nails, etc......didn't cover anything, and was sanding compound with dust f'n everwhere.....in my tools,(at least she covered the car)
I was like ...thank you, but WTF are you doing....
After the wheels are done, will paint the walls, floors, wtc......Cylon, sounds like you want to volunteer to help.
92 ZR1
#234
PS you seem to know alot about fat chicks and dresses, anything you want to tell us, its ok let it out
Old 06-08-2008   #5
I am going to get a decent set of spacers, won't be picking up a set from autozone.
Looking at a set Jeff sent me a name for and H&R
92 ZR1
#234
Old 06-08-2008   #6
Holly Chit !!
No thanks already painted mine !!!
92 ZR1
#234
Nah HADI told me all about it!
Old 06-08-2008   #7
[IMG][/IMG]I got a really nice set of hub centric spacers made buy a guy in L.A. H.C. to car and H.C. to the wheel.WVZR1 hooked me up with this guy.Ive also got 2 sets of spacers that I had made Im not using,hub centric to the car only.One set is 9MM and other is 12MM.The picture is of the 16MM spacers Ive got on the car.
Old 06-08-2008   #8
WVZR-1
When I did my spacers I used the 14mm difference of the ZR-1 spec wheel and the GS spec wheel and there appeared to be substantial clearance tire sidewall to quarter wheelhouse with my ZR-1 spec wheels mounted so I added 2mm to each wheel spacer. I was tempted to try 18mm spacers, I believe they would have been fine.
The spacer is "hub centric" and a better fit to the bearing flange than an OE wheel and the wheel stud bores are "snug". The spacer flange is a duplication of bearing flange.
I'd compare the "back spacing" of the GM ZR-1 wheel to the "back spacing" of your wheels to calculate the spacer thickness. Assume "nothing"!
Old 06-08-2008   #9
WOW, those look really nice.. how much were they?
Old 06-08-2008   #10
You dont want to know.... A gun and a mask was involved
