Old 04-13-2008   #1
ZR1Vette
ZR1Vette's Avatar
Default Will this scanner tool work on the LT-5>>>
http://www.actron.com/product_detail.php?pid=16152
Thanks
Michael
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 04-13-2008   #2
bradslt5
Default Re: Will this scanner tool work on the LT-5>>>
yeah ,but its a cheap version of what you need it will read trouble code but i believe you have to count the flashes to find the codes that are set . a decent tool will give you actual led readouts .
Old 04-13-2008   #3
Aurora40
Aurora40's Avatar
For that type of code reading, save your money and use a paperclip.
I wouldn't call that a "scanner", as they generally retrieve operational data from the car. That's simply a code reader. If you didn't have any codes set, that tool wouldn't be useful at all for diagnosing any drivability issues.
If you want to see some stuff before you buy it, I've a EZ Scan 6000, as well as TTS Datamaster on a laptop you can check out. I can bring it to Chik-Fil-A sometime if you are interested.
Bob Saveland
Former owner of #2517
Old 04-13-2008   #4
ZR1Vette
ZR1Vette's Avatar
Cool.. see you at Chik F A gathering.. I just want something I can monitor codes on the routine basis
Michael
Michael
:cheers:
Old 04-13-2008   #5
Aurora40
Aurora40's Avatar
Michael
I don't go there that often, so let me know when you want to meet up and I'll bring the stuff.
Bob Saveland
Old 04-14-2008   #6
Michael
Just a suggestion, I bought the Gordon Killabrew "jumper package"...forgot how much $ it was...not too much if I recall. You get a book with the short version of the codes, what they are, and you can use the jumpers to clear the DTC's and see if they reset. I keep them in my glovebox as they are great for use anywhere.
For me they are easier to use than the paper clip because you don't even have to look at the ALDL connector....just pick the "jumper" for the system and plug it in the ALDL....for example you get a jumper for the ECM, FX3, CCM, SIR, ABS, & I forget the sixth one...but you get the idea.
Old 04-15-2008   #7
cope05
I would like to purchase a diagnostic tool that works via a laptop, does anyone have an opinion on what make/mosel is the best?
Thanks
cope05 is offline   Reply With Quote
Old 04-15-2008   #8
Aurora40
Aurora40's Avatar
TTS Datamaster is nice because you get 20 records for free before you have to buy it. So you can try it out before committing. You just need a laptop and a cable.
Bob Saveland
Old 04-15-2008   #9
I was workign on the Definition file to use ScannerPro, I need to try it this summer once I finish it..
Old 01-19-2012   #10
Torchred96
I know this is an old post..see I do search!, But I downloaded datamaster and now, I'm wondering what to do with it. Do I just need a usb to aldl connector cable with my laptop to start reading what's going on with all the parameters that are monitored?
It's not easy trying to learn this stuff without help. What's the best way to learn about setting/tuning the different sensors and what's going on with the injectors, which are firing, which are not, same with spark plugs, coils, dic, etc. etc.?
I'm pretty good with an multimeter, just have to be told what to do with it
Sam
1991 ZR-1
:salute:
Torchred96 is offline   Reply With Quote
