03-20-2008 | #1 |
Cam Cover Bolts
Spotted these -
http://cgi.ebay.com/ebaymotors/ZR-1-...em260222135124 Anyone got any comments on these? They look a good deal on the surface, but I'm suspicious.
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
03-20-2008 | #2 |
Re: Cam Cover Bolts
Maybe the right size, but doesn't look to be a Torx head.
Looks more like a Allen head. And pardon my stupidity, but what is an A/N Washer? Tom
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by tccrab; 03-20-2008 at 01:20 PM. |
03-20-2008 | #3 | |
Re: Cam Cover Bolts
03-20-2008 | #4 |
Re: Cam Cover Bolts
AN is a size standard. Air force-Navy I believe is where it originated from.
My opinion the washers are garbage as I have never seen one with a rubber seal on it. |
03-20-2008 | #5 |
Re: Cam Cover Bolts
Dave,
If you are thinking about bolts, get them from Jeff. I used his when I redid the engine. He has everything you need.............
03-21-2008 | #6 | |
Re: Cam Cover Bolts
Right now I'm trying to put the stuff together for the C5 brake swap. I have calipers from a guy upgrading his C5, I picked up some stainless lines here on the forum . I just need the adapters and rotors now.
