Old 01-24-2008   #1
Sgreg
Sgreg's Avatar
Default Anyone using an Electronic Ratio Adapter ?
I am doing a rear gear change and kind of like the versatility of an Electronic Ratio Adapter (ERA) for recalibration of our digital speedos. Does anyone have one of these ? Do you like it and is it accurate ? Where do you mount it ? Sorry for so many questions. Just want to find out if it is something I want to do. Thanks.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 01-24-2008   #2
guinnessdood
guinnessdood's Avatar
Default Re: Anyone using an Electronic Ratio Adapter ?
Contact Bill Boudreau. I understand he has been installing them with rear end gear changes. www.zfdoc.com
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 01-24-2008   #3
40th#381
I have used the electronic speed calibrator for about 8 years.
I first put 4:30s in didn't like them then 4:10. I like them. Have 335s
on rear now. Recalibration is just a switch away.
Jan
40th#381 is offline   Reply With Quote
Old 01-24-2008   #4
Jeffvette
Use the gears from Marc. Not that hard to install. I've seen a few boxes and the install was crap. Plus with all the wiring you have just introduced another electrical failure point.
Old 01-24-2008   #5
DaveK
I bought one but never installed it. The problems I could see were:
1. You had to cut the wiring (it could have been made a plug-in job but I guess the 50 cent connectors were just too expensive...)
2. Where the wires came out of the box was just a big hole drilled through the plastic case. No sealing or anything to protect the components inside from damp, gunk etc.
3. No way to secure it easily (no plastic 'belt loops' or anything.
4. The thing needed mounting under the car close to the vss output on the gearbox. So not really much easier than doing the gears.
The box I ordered was from Corvette Central, others may be different. I decided to get the gears from Marc.
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 01-25-2008   #6
blackjack
i am using one too....they work fine,but the installation looks sh.t
bj
91/1735
Old 01-25-2008   #7
Sgreg
Sgreg's Avatar
Thanks, for the comments. Don't think ERA is for me. Buying gear from Marc.
