01-22-2008 | #1 |
Balking issue: More info...
At the risk of sounding like I'm comiserating, I discovered yesterday that the balking & "stuttering" (we're talking a transmission lash-whacking jolt) will occur with the valet switch (full power) turned "off" as well as "on". Hmmmm...sez me. Here's some more info:
Fuel/air/spark... Fuel system fault probability % estimates (swag!):
That said, I'm trying to run down a source for coil packs. The best the local GM dealer would do was $80.xx ea. And, asside from the "16 hole" plenum gaskets, I'm looking for a better deal on plug wires too; a "package" for a plenum yank, if you will! (Jeffvette???) What am I missing? Does any of this make sense? Or, should I just shaddap and go pull the damn plenum and leave y'all alone?? Maybe I'm just having too much fun. One thing does strike me tho... Among my varied past endeavors, technical training development is one of them. It occurs to me that perhaps someone like me (and others) could benefit by a series of short manuals; LT5 (or whatever) for "dummies". It could be in print and/or electronic format - even some movie clips - that would cover a variety of LT5 and ZR-1 topics. I envision a concept piece that would be repleat with photos and diagrams and some effort to gather the pertinant (and far flug!) scraps of information from the FSMs, and put it where someone could quickly grasp the what, where, how-to stuff in one place. I see it utilizing "subject matter experts" (SMEs) perhaps and especially from this board and other authorities to assure completeness and accuracy...Ya think that would be worth doing?? Thanks in advance for any thoughts (on any aspect of this windy post!) P. |
01-22-2008 | #2 |
Re: Balking issue: More info...
Can you datalog the car while it is doing this?
01-22-2008 | #3 |
i agree with the above post that would help in figuring your problem alot
01-22-2008 | #4 | |
P. |
01-22-2008 | #5 |
Paul,
although I'm no mechanic, which many here will freely agree and comment upon. I do retain a bit of knowledge of things that have happened to me before. albeit, not all. with that pretense in mind, My car, 1990, #0074 had some similiar problems as you have described, Upon acceleration, it would sometimes, fall flat on her face, fart, then, pick right back up, It didn't matter whether hot or cold. and she did it when she wanted. a few months of this, and, upon arriving in Bowling Green for the gathering a few years ago, I was explaining my problems, to anyone that would listen, standing around my open clam shell. Gordon Killibrew and a host of others, were looking and talking about stuff. Gordon told me he thought it was the map sensor hose, collapsing upon acceleration, He said, if the hose was soft, and pliable, that would be one of my problems, he was right, and the next morning, at the Museum, I went to his tent, and he cut me a piece of new hose, showed How to replace it. He also said he the air cleaner needed to be replaced. I had dyno'd the car the day before, and after the new map hose and the air cleaner, it dyno'd and extra 22 hp. Holy mother of pearl, i was suprised, and delighted, and the hesitation was history. Of course you probably already know, but the map sensor hose, is located right in the back in the middle of your plenum, there is an aluminum bracket, that you take off to get to it. Here's hoping it is something as simple as that. |
01-22-2008 | #6 |
Paul, give me a call.
01-22-2008 | #7 |
You have the thought process down but the specific steps could use some work.
1. Compression check. 2. Run the car, park it and look at the plugs they should be uniform in appearance if not then chase fuel/spark on that cyl. 3.Take a good known plug and one cyl at a time unplug the wire, plug in the plug, lay it on the plenum and start the car. The spark should be the same on every cyl if not then you know which coil pack/wire to chase for problems. 4. There is a DIS checker and should you suspect the dis of falling apart I can lend it to you. You need some kind of a scope to look at the signals to verify its falling apart. 5. If you pull the plenum then you can check the injectors by pulling fuel rail up, crank the car and look at the spray pattern. 6. If you have a suspect cyl you can eliminate spark with step 2 and check fuel by swaping injectors from cyl to cyl, this requires pulling the plenum but you get pretty good at in with practice. 7. Listen for the vacuum pump at the left front of the car. You should hear it cycle for a couple of seconds when the key is first turned on the go quiet for at least 5-10 minutes. Both failing to pull the vacuum, on start and an continuly cycling pump signal problems that will cause what you describe. Let us know what you find. Tyle
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White Last edited by Tyler Townsley; 01-22-2008 at 08:25 PM. |
01-22-2008 | #8 |
Only thing I can add to the knowledge here:
My 90 had a huge stumble @ 2500-3000 until I changed the O2 sensors.
1990 Grey/Black Too many for the sig. |
01-23-2008 | #9 | |
Well...
Truth be known, this "little" annoyance I'm experiencing is giving me a reason to spend hours researching the LT5's operation - what makes it tick. This way I can be really dangerous!! P. |
01-23-2008 | #10 | |
Easy enough and cheap enough to replace it, so I'll put it on the list when I pull the plenum. Thx for that! P. |
