01-09-2008 | #1 |
What is this?
Thanks
01-09-2008 | #2 |
Re: What is this?
Power distribution block/junction.
01-09-2008 | #3 |
Re: What is this?
and it's clean too ...
01-09-2008 | #4 | |
Re: What is this?
01-09-2008 | #5 |
Re: What is this?
Thanks you guys... I wondered if that's what it was.... all the same color wires coming out seemed strange, thats why I asked.
Thank you |
01-09-2008 | #6 |
Re: What is this?
There is a rubber tube thing that hangs down over that block....it drains water from up at the cowl...you wanna check that you re-rout that tube and the water away from that block. or at least check it.... mine was aimed right at that block.
My block is that clean....I cleaned it myself & it's the cleanest part that ya never see on my car...the rest of the under side stuff has this nice patina of excercise grim on it!
01-09-2008 | #7 |
Re: What is this?
It's an alien, maternity gyroscope condenser.
that or maybe..a power whatchamacallet blockhead junction thing..E Was this a quiz? Will this be on the final test? I can't find it in my notes....I'm screwed |
01-10-2008 | #8 |
Re: What is this?
Thanks for the compliment Jeff.
Good advice on the drain tube, I'll go look at it this morning. Thanks No test test here, just the facts :-) |
