Old 10-31-2007   #1
kenthompson
kenthompson's Avatar
Default x-pipe
Would the experts recommend replacing the resonator with an x-pipe? Since the exhaust is out anyway, now would be the time to put one in if it's worth it.
I'm planning to get a set of headers ASAP.
1990 Grey/Black
Too many for the sig.
kenthompson is offline   Reply With Quote
Old 10-31-2007   #2
bradslt5
Default Re: x-pipe
an x pipe will increase your mid range about 10 hp .it sure did on my trans am firebird . you might get more cabin noise though.from what i read here the resonator is the cork on the stk exhaust
Old 10-31-2007   #3
Z Factor
Z Factor's Avatar
Default Re: x-pipe
It really depends on what you are looking for. Will an x-pipe be less restrictive and therefore give you a little boost? The answer is yes. Will it increase the exhaust note? The answer is yes. Will it increase the resonance in the cabin, the answer is typically yes. The most restrictive part of your stock exhaust system is the one piece manifolds/cats, so replacing them with headers will make a noticeable difference. Just keep in mind that headers with no cats + an x-pipe will be loud. Some love it, others don't, so you may want to listen to a few different set ups.
Old 10-31-2007   #4
John Boothby
John Boothby's Avatar
Default Re: x-pipe
Ken, also keep in mind the Nevada emissions standards. I do not believe that you can "legally" remove any part of the stock emission control system, including the cats.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 10-31-2007   #5
kenthompson
Default Re: x-pipe
Oh, I was planning on going to high flow cats. The state law the way I read it says you can legally replace cats over five years old.
.....now the air injection setup......(just for the weight factor)
And the car still has the power effects exhaust mufflers.
1990 Grey/Black
Old 11-01-2007   #6
John Boothby
Default Re: x-pipe
Yes you can replace them, you just can't remove them altogether.
Good luck on your mods!
JB
:cheers:
Old 11-01-2007   #7
Aurora40
Aurora40's Avatar
Default Re: x-pipe
You can legally replace cats over 5 years old if they are defective. Federal law governs this, not states. However states may or may not test for emissions output and devices.
Bob Saveland
Former owner of #2517
Old 11-01-2007   #8
Belsy
Belsy's Avatar
Default Re: x-pipe
I went with 3" from cats back with X-pipe and lost some bottom end but feel mid & top gains! X was easy and sounds good, but as most systems has some resonance. Pic attached !
Gene in Fl. :handshak:
______________
95 ZR-1 #399
Dunn heads
X-pipe w/3"
misc. mods
Belsy is offline   Reply With Quote
