Old 10-22-2007   #1
va beach biker
va beach biker's Avatar
Default A/C blower failure.
My A/C blower died on the way home today. I got the flashing indicator light above the auto button on the control panel, and then all airfow pretty much stopped. This was right at start up. Code 00 (no fault) came up when I ran the diagnostic check. I also reset the system by pulling the radio and courtesy light fuses. I was going to check the blower motor fuse under the hood, but I can't find it, going off the service manual illustration.
Any ideas?
1991 Red / Black
SLP Intake / Haibeck Chip / B&B Catback
va beach biker is offline   Reply With Quote
Old 10-22-2007   #2
va beach biker
Default Re: A/C blower failure.
Problem solved. I did a little searching on other A/C issues, pulled my negative cable for a minute, put it back, and things are good to go.
1991 Red / Black
Old 10-23-2007   #3
DaveK
Glad you got it fixed. Any idea why that worked though?
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 10-23-2007   #4
va beach biker
I've read about other owners having electrical problems, that pulling the negative cable fixed. I think there was even a help hint in the electrical supplement to the tech manual that recommended doing it first, before any further troubleshooting.
1991 Red / Black
