Old 08-06-2007   #1
pig_iron
Default Hole in fuel line
To make a long story short, my dumbass accidentally drilled a small hole into the fuel line on the passenger side just below the door. Is this repairable, or am I going to have to purchase a whole new fuel line? If so, where do I get one?
pig_iron is offline   Reply With Quote
Old 08-07-2007   #2
Jeffvette
Default Re: Hole in fuel line
Return or feed line? And what year?
Old 08-07-2007   #3
pig_iron
1991. I'm guessing it's the feed line because it's been leaking for the last 6 hours..
It's the line right below the passenger door.
Old 08-07-2007   #4
pig_iron
Okay I didn't realize there were 2 lines there. The one that's leaking is the inside one. So whichever that one is. It has finally stopped after about 10 hrs, and I am assuming my tank is empty because it was very low when it started.
Old 08-07-2007   #5
Jeffvette
Feed - 10052173
Return - 10052179
Both are discontinued. I'll check dealer inventory in the morning.... or a few hours actually.
Old 08-07-2007   #6
pig_iron
Damn... If they're both discontinued is there a way to repair them?
Thanks for checking man.
Old 08-07-2007   #7
8upZR1
8upZR1's Avatar
I would not try to repair the line if I were you. You should try White racing, that is who I go to for discontinued stuff. Usually is not a hassle either. Good luck with the fuel line.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!!
8upZR1 is offline   Reply With Quote
Old 08-07-2007   #8
Jeffvette
Sending you a PM with the contact info. There is 1 left.
