Old 07-30-2007   #1
cuisinartvette
Default Thermostat sealing problems
Looks like I may need another seal (anybody have one?), this one wont seat up no matter what I do.
The outer housing DOES bolt to the ouside of the frame rail, no?
Sorry,its been apart a long time.
Seems so simple yet pees water out as I pour it in.
I noticed to get the seal/thermostat to stay in place I have to kind of push it into the rear opf the housing and it doesnt wanna lay flat, anyone have a little trick I missing to get this thing into place?
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
Old 07-31-2007   #2
jonszr1
jonszr1's Avatar
Default Re: Thermostat sealing problems
ron ,sorry i didn,t get back toya sooner but just now got back in town. how did you put the gasket on the therm. it the gasket is attached in that little groove in the rubber if you look at it sideways after you attach it there a little slope bigger a top and smaller towards the little end. aand of course you are putting the little end towards the engine. .make sure also that the grooves are clean. if you are still having a problemm give me a call around 8 am
Old 08-01-2007   #3
cuisinartvette
Ok, I was just notified by phone I am a retard and agree.
Thats about it.
Old 08-03-2007   #4
cuisinartvette
Welp, after a year she started right up and idled like a kitten, no rattles, smoke, leaks, nothing. What a motor. Now to get it back on the ground and put some miles on it before shelving it again.
Best part was the vacuum pump doesnt run anymore, suspect I hmay have had a slight leak at the TB and not known it.
Old 08-03-2007   #5
QB93Z
QB93Z's Avatar
Good Job! Nothing better than hearing that engine burst to life for the first time!! Glad to hear that its running again.
Old 08-04-2007   #6
cuisinartvette
Now to get it back on the ground, had to have some shock bushings and actuator clips overnighted.Hopefully Sunday I can go for a spin.
Fwiw, Randy at Doug Rippie was a pleasure to deal with.
Old 08-05-2007   #7
Peaven
Peaven's Avatar
Congrats on getting her running again Ron, you've certain waited a while.
SteveB
'94 ABZ Lucky #13-SOLD
Peaven is offline   Reply With Quote
