Old 07-27-2007   #1
jrd1990zr1
jrd1990zr1's Avatar
Default 1990 MAP sensor
This may sound like a stupid question. Where is the MAP sensor on a 1990 ZR1 installed? My car is kicking out a code 33.
Thanks
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 07-27-2007   #2
jonszr1
jonszr1's Avatar
Default Re: 1990 MAP sensor
its at the very back center of the olenum(intake) you will see ahorizontal alluminum piece unbolt it (torx bolts) 2of them. disconnect the connector take the vaccume hose off .its not hard .easier with1/4 in drive ratchet and torx bit/ hope this helps
Old 07-27-2007   #3
GrayZ
rear center, under the aluminum bracket, you can use
your roof ratchet to get the torq bolts off.
check the hose, make sure it's still rigid, if it's pliable
it's toast, replace that bad boy.......party on
GrayZ is offline   Reply With Quote
Old 07-28-2007   #4
jonszr1
jonszr1's Avatar
Roof ratchet . really very cool but my hose is still stiff
Old 07-29-2007   #5
jrd1990zr1
jrd1990zr1's Avatar
Found it.
Thanks!!!!!!!
