06-26-2007 | #1 |
Upgrading the wattage in driving lamps
Has anyone upgraded the stock bulb of 34 watts in the driving lamps?
Thanks for your time. George |
06-26-2007 | #2 |
Re: Upgrading the wattage in driving lamps
i dont know either but would sure like to. i always use just the driving lights at night.....gives it a much meaner lower look. and i have thought about getting a little brighter lights so i dont have to worry about the po-po pulling me over.
06-27-2007 | #3 |
you can put in 50wat driving lights plus you can adjust them to project out farther the stk bulb is part number 880 the 50 watt is 885. you must though put a 15amp fuse in place of the 10 amp fuse . i drive around with the driving lights on all the time since i have changed over and readjusted them. it really looks cool now
06-27-2007 | #4 | |
trick. The wiring was engineered for the original current load and increasing the current "might" be OK, but a quick check of the wiring to make sure it's not getting too warm is in order. Or check the shop manual wiring diagrams to see what gauge wire is used. It might be adequate but then again ... Glenn 91-1341 MSEE Purdue 1967 |
06-27-2007 | #5 | |
06-28-2007 | #6 |
no the fuse is exactly the same just has a higher amp rating . the wire is no problem. it can handle twice the amps before being a problem. . remember you are only raising the fuse 5 amps. i have had this change in effect for 2 years with no problems.
06-28-2007 | #7 | |
06-28-2007 | #8 |
its a generic number used by kragen auto zone. etc like our headlights are 6054s.does that help? let e know
06-28-2007 | #9 | |
Hans
06-28-2007 | #10 | |
