06-24-2007 | #1 |
Stalling at stop
My 90 recently started to stall at slow down to idle(as approaching stop) yet restarts and runs fine with no codes!! Seems to be worse with A/C on. Only recent change was 3" exhaust eliminating much back pressure, other items are Haibeck chip and open air box which seemed fine till recently. 30,000 mile car w/ new plugs and wires at 28,000 miles. Open for suggestions!
Any thoughts??? Gene in Fl. |
06-24-2007 | #2 |
Re: Stalling at stop
ck your iac, could be dirty or bad. also ck tps to see if it is .54. 3rd ck to see if map sensor hose has come off.
06-24-2007 | #3 | |
06-24-2007 | #4 | |
Thanks, Gene |
06-24-2007 | #5 |
Gene , no problem we all gotta learn , iremember all my ?s at first. but the guys were nice and still helped . the Iac is on the passenger side of the throttle body . there is a water tight connector on it . it has 2 small torx bolts that hold it in. there is also a o ring that dreates a seal . you could take it off and spray carb cleaner on it . just be carefull dot wipe it just spray.. a couple of thoughts . have you cked the pvc val;ves or the rubber hose where the pvc valves located for a leak these have a tendancy to go bad. DO YOU HAVE A HELMS MANUAL. if not get one they really help alot .just take your time looks scaryer that it really is. or see if there is another zr1 er in your area that might help ya out .
06-24-2007 | #6 | |
Gene |
06-24-2007 | #7 |
you got the big fat red manual with the electric and engine suplement.they can really bug ya on the order of things in the book. but once you learn that system its way more detailed than the other. ck the map sensor vac line .it at the back of the motor up against the wall
07-05-2007 | #8 |
My Z has started doing the same thing. I've alreday checked the MAP sensor hose. I will try cleaning the IAC next
thanks
Red/red 90 #1281 (UK) Marc Haibeck 368 B&B, Brembos DRM suspension Known as 'Gixer' on corvettechat.co.uk www.corvetteclips.co.uk |
07-05-2007 | #9 |
the best piece of equipment i got is the scann tool .i keep it hooked up even while driving . it really lets you know how your caris doing. help diagnostics too. jmho
07-05-2007 | #10 | |
