Old 05-17-2007   #1
TCHoward
TCHoward's Avatar
Default Severe miss after driving for a short period of time
I recently purchased a 1990 ZR1. After driving the car for a short time there is a severe miss happening. The engine starts to shudder. When given gas the miss is still there. After a minute or so the miss goes away. Has anyone encountered this?
I have taken the car to Mr. Goodwrench and they said they found a vacuum leak which they fixed and the car still has the miss.
Miss may not be the correct word but that's what I'm using for lack of a better one.
TCHoward is offline   Reply With Quote
Old 05-17-2007   #2
TCHoward
TCHoward's Avatar
Default Re: Severe miss after driving for a short period of time
Sorry folks for putting this thread in the wrong forum. Should have been in the technical forum I guess.
Tom Howard
1990 Red on Red #219
Old 05-17-2007   #3
tccrab
tccrab's Avatar
Nah.. This is as good a place as any to get started.
First things first,
Welcome to the Registry!
You've come to the right place.
Intermittent problems are typically the hardest kind of problems to diagnose.
Is the SES light lit on the DIS?
Have you pulled the codes?
Is the car hard to start?
Do you get a lot of smoke on startup?
Are your secondaries functioning?
What work has been done to the car by the previous owners?
How many miles on the car?
Describe as accurately as you can what this miss/shudder sounds and feels like.
Does it miss at speed and at idle?
Does it go away when you open up the secondaries?
I'll cut some slack to your local Stealership, maybe the miss didn't occur when the car was in the shop and therefore they couldn't diagnose it.
But to be blunt, most Chevy shops have never seen a ZR1, much less have somebody that is trained and certified to work on the LT5.
More info will be needed before we can give a marginally accurate armchair diagnosis.
Where are you located?
There are half a dozen or so *really_really* good ZR1 tuners out there, maybe one is reasonably close to you.
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-17-2007   #4
Kevin
Kevin's Avatar
if you have a digtal cam that does video and a buddy get a vid of what the car is doing and upload and post here.
Some basic things to check:
how many miles are on the car
was it driven at all
Old 05-17-2007   #5
TCHoward
TCHoward's Avatar
Hey thanks for the welcome!
My ZR has 35K miles and it seems best I can tell from all of the records that I received with the car that most of the miles ere put on within the first couple of years. The last couple of years I would say that less than a 2000 miles have been put on it. I did see repairs for a couple of injectors.
I believe that the secondaries are opening. I can feel them kickin when getting on it. On another thread I did see that someone was experiencing the same symptoms and the response was that the injectors are probably shorting out when the motor gets to operating temperature. That seems to be the problem that I experience as it only happens when the motor is at operating temp. The strange thing is that it will go away in a couple of minutes after it starts. This morning I drove it to work and the temp outside was around 55 to 60 and sure enough after the engine got to temp it started missing. Couple of minutes later it stopped. Drove home this evening and it was around 85 and did not have a problem. Stumped.
By the way I live in Dallas TX. If anyone knows of a great tuner in this area please let me know.
I hate to go off half cocked and replace the injectors if they don't really need to be replaced. Secondly they are expensive!
Anyway I don't know if this shed any more light on the problem.
Thanks for all of your inputs!
Tom Howard
Old 05-17-2007   #6
Kevin
Kevin's Avatar
I know it's a bit of a haul but you may want to take a run over to cory hendersons shop in new braunfules http://www.hendersonperformance.com/index.html
Old 05-17-2007   #7
1990 quasar blue
You can test them with an Ohm meter. If they are bad Accell's can be had for 432.00 a set plus shipping.
http://www.autoshopracingengines.com/
Part # 150121 about 27.00 each and you'll need all 16
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 05-17-2007   #8
TCHoward
TCHoward's Avatar
Thanks once again. I will give Henderson's a call. Just a couple of hours down the road from Dallas.
Tom Howard
Old 05-17-2007   #9
tccrab
tccrab's Avatar
Here's what you need to check the primary injectors without removing the plenum, courtesy of Marc Haibeck, "The ZR1 Specialist":
http://www.zr1specialist.com/HAT%20W...Resistance.htm
And since the write up is for a '91 and you have a '90 here's the correct page for a '90 from my Helms manual:
Good luck!
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-17-2007   #10
carter200
carter200's Avatar
Contact EES at www.acsvette.com and Mike will fix it right By the way, welcome
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
