Old 11-06-2021   #1
Norwegianmopar
Norwegianmopar's Avatar
Default Brake upgrades
Without breaking the bank with Brembo or Baer brakes etc, is the cost of a C5 conversion kit worth the $$$ over slotted and drilled rotors with quality pads as a direct replacement for the original rotors?
Here is an example of the latter:
https://www.ecklerscorvette.com/1988...ails_tab-title
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 11-06-2021   #2
Default Re: Brake upgrades
J55s are pretty good, in a 1991 Test they did 155 ft from 70, thats with old tech tires and pads. A c7 corvette can pull it down from 70 in 130-135 feet with big Brembos.... so take a 91 Z with J55s add in good pads, bias spring, and new modern tires you are not far off pace... repeated stops or on the track you will see a difference but daily driving the J55s are nice.....
https://www.caranddriver.com/reviews...mparison-test/
Old 11-07-2021   #3
Young1
Young1's Avatar
Doug Rippie bias spring
Power Stop Z23 or Z26 pads
Stainless brake flex lines
High temp fluid
Russell speed bleeders
Master and calipers fresh
Do a clean up cut on stock rotors
300 wear rating tires
The engineers did a good job. You will surprise yourself what it can do on the street and on mountain roads. My practical nature says use stock to its maximum potential.
Steve Young
Second Owner
SOLD
SOLD
Old 11-07-2021   #4
Norwegianmopar
High temp fluid
Very good points, thanks. DRM brake stuff is going on my shopping list [emoji106]
I would think upgraded rotors in combo with said parts would be even better than cleaned up stock ones..?
https://www.powerstop.com/product/po...ior-brake-kit/
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 11-08-2021   #5
Matt B
Matt B's Avatar
Thumbs up for power stop Z26 drilled/slotted rotors plus matching pads. Following the recommendation of the brotherhood I upgraded my 30 years old stock brake system and it works great. No noise (I mean NO) and very little brake dust (yet more than on quality ATE Ceramic Pads). Brake dust is grey so you don't recognize it too much on argent wheels.
Brake force is good, yet the modulation can not keep up with modern cars to my opinion. You get what you pay for, i.e. heavy brake power will need heavy leg power as input, still. Neither is it as sensitive / giving good feedback like a modern brake. But the overall stopping power is great and does THE BEAST justice.
Braided hoses probably improve the feel. They're on my list.
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 11-08-2021   #6
Norwegianmopar
Thanks for the reply. Looks like the way to go.
I think I will add these from DRM since I already consider the DRM coilovers :
https://www.dougrippie.com/c4-corvet...el-brake-lines
https://www.dougrippie.com/brake-bias-spring
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 11-09-2021   #7
Matt B
Matt B's Avatar
I'm also thinking about the DR spring... Does he ship to Europe?
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Old 11-09-2021   #8
I went with Wilwood six piston narrow lights calipers up front and c5 four piston calipers for the rear with front and rear Baer eridaspeed 3 piece rotors. DONE!
Here is the money shot on the rear
File Type: jpg 956F1477-2AB7-49BA-BCE7-AB1C78E65405.jpg (90.6 KB, 39 views)
Old 11-09-2021   #9
secondchance
Wilwood 6 pistons up front and Wilwood 4 pistons rear with Mr. Parker?s parking brake set up.
http://www.zr1.net/forum/showthread.php?t=24546
Old 11-09-2021   #10
G8nightman
G8nightman's Avatar
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
