05-07-2021 | #1 |
C7 brakes on a 90 ZR-1?
Gents,
I'd like to upgrade my front brakes on my 90 ZR-1. Some initial research shows that the C7 front caliper "can" work on our cars. There's a thread on the Corvette forum where a gentleman did c7 calipers/aftermarket rotors and a spacer. Anyone here done this already? Open to recommendations. I currently have 19" Forgestar F14's on all (4). So, clearance won'te be an issue. Thanks in advance!
-------------------- 2008 Black Z06 3LZ 1990 ZR-1 #1797 1979 Trans Am 1971 GTO Judge tribute Last edited by 1971 Judge; 05-07-2021 at 08:37 PM. |
05-08-2021 | #2 |
Re: C7 brakes on a 90 ZR-1?
I have C6Z brakes on my 92.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 03:09 PM. |
05-08-2021 | #3 |
I went with Wilwood 6 pistons front and 4 pistons rear.
https://www.zr1.net/forum/showthread.php?t=24546 |
05-08-2021 | #4 |
Did you have to do any fabrication - or puchase additional parts (minus calipers/rotos) to do the swap? Thanks.
-------------------- 2008 Black Z06 3LZ 1990 ZR-1 #1797 1979 Trans Am 1971 GTO Judge tribute |
05-18-2021 | #5 |
i installed a set of c6 z06 rotors/calipers/wheels and tires on my 91 zr-1. open this link and go to post #3. to mount a set of c7 calipers i would think that you would only need to find someone to manufacture a set of brackets as the bolt distance is different from the c5/c6 bolt pattern.
https://www.corvetteforum.com/forums...c4-zr-1-a.html |
05-18-2021 | #6 | |
Here?s a thread outlining the conversion. Apologies if its a dupe. https://www.corvetteforum.com/forums...onversion.html
