Old 12-06-2020   #1
Karl
Karl's Avatar
Default 93' and up weight difference, where does it come from?
Where does the extra weight come from in the '93 and up cars?
I am removing unnecessary weight from the car and want to know why the later years weight more.
I have talked with Pete and reviewed Marc's website on the topic. I assume it is not the EGR and ASR system, but every pound counts.
Thank you,
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 12-06-2020   #2
Vette73
Default Re: 93' and up weight difference, where does it come from?
These were a little porky out of the factory....I know on my 91 I went to a 14 lb fidanza flywheel...Went w headers to remove the heavy cats...The OBX catback was lighter then the stock cat back as well....Removed rear spare tire with jack and lug wrench.
Removed vacuum accessories when I deleted secondaries ( maybe a couple of pounds
..Use the tinted top instead body colored one, maybe its 5 pounds lighter...Went with A molds and sold the factory sawblades....Sawblades are a little heavier...Went with slotted aluminum rotors,instead of the factory iron ones..
Yep every little bit helps....
Vette73 is offline   Reply With Quote
Old 12-06-2020   #3
Karl
Karl's Avatar
I have all the above mentioned weight savings and then some, except I use a ~20lb flywheel and have the stock rotors.
I am more concerned about where the extra weight comes from the factory in the later model years.
Old 12-08-2020   #4
Hib Halverson
I can remember back then some discussion at press previews between media, myself included, and Chevrolet PR folks about what drove the increase in curb weight but, at this point in time, damn if I can remember what it was.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-09-2020   #5
EvanZR1
EvanZR1's Avatar
Redesigned seats, extra sound deadening material, passenger airbag, additional crash structure/bracing?
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
EvanZR1 is offline   Reply With Quote
Old 12-09-2020   #6
Karl
Karl's Avatar
Hib, if you can think of anything please post.
Evan, the seats changed in 1994 -1995 and I am pretty sure there is no passenger side airbag in my '93.
I am thinking it is insulation, sound dampening, and antivibration materials used to improve the overall ride and build quality.
The door panels changed in 94 also. I believe they are a pound or two lighter each.
Only difference I can think of between the 93 vs 94 & 95 is the seats, door panels, and passenger side airbag.
I don't see 50 lbs there.
I feel like I have one of these stuck to my car....
Anyone have any additional information?
Old 12-09-2020   #7
Erik
I was just reading about this! But where? Let me check my library and I'll get right back to you.
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 12-09-2020   #8
Vette73
Too lazy to Google ....What is the weight difference like 50 pounds ? Considering these cars were the most expensive GM produced in the 90's it would have been nice if they lightened certain body panels...
I'm sure many of you own C5 Z06's...You can raise the hood on that car with one finger as opposed to a shoulder press when it comes to the ZR-1....I realize it is a bigger hood but there are many spots where they could have shed the weight..
Of course a decade and a half later Chevy built the LS7 Z06 with lightweight panels and a car with 505 HP that weighed all of 3,100 pounds..
Old 12-10-2020   #9
Rodder
A long time ago I read performance numbers through 90-95 and what struck me was the weights. You always read how heavy the later years are. Did a search and found it, was Jim Ingle?s text.
https://www.corvetteactioncenter.com/tech/perform.html
Even if fluids are not down to the ounce, calibration of the scale and what ever, engineers have an mind setting for keeping them "good enough " for what they presenting. Anybody else put different year cars on a scale?
Thomas
Rodder is offline   Reply With Quote
Old 12-10-2020   #10
spork2367
Impact absorbers on later years are lighter as they are foam compared to 1990-92 molded plastic.
