04-08-2007 | #1 |
help with lowering bolts???
hi all, i am wishing to lower the arss of the Z an inch or two. i have heard it is a simple bolt chang. anyone know what size bolts and the procedure to do it? thanks
04-08-2007 | #2 |
Re: help with lowering bolts???
Thanks for the post, I am very interested in this mod also. I was just talking with Demps about that yesterday. Waiting to hear from others.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
04-08-2007 | #3 | |
04-08-2007 | #4 |
It's really easy. Vette Brakes and Products sells the bolts you need for about $20. They're 2 inches longer than the stock bolts. To do the swap. get the rear of the car up in the air with jack stands under the frame. Then put a jack under the rear spring on the side you want to change. Make sure the jack contacts the metal pad ot the end of the spring, not the fiberglass body. Raise the jack slowly until it lifts off the spring cushion (a rubber cushion). Remove the cotter pin, nut, and bolt, and install the new bolt the nut. This is also a good time to replace the spring cushions which get a tad raggedy with age.
The nice part about the afternarked spring bolts is they allow you to adjust the height as often as you like. They also allow you to compensate for the factory lean found on some cars. |
04-09-2007 | #5 | |
