09-13-2019 | #1 |
Door Hatchback Release Switch
On my 93, the door hatchback release is not working. It was intermittent but now it doesn’t work. The release button in the console works as well as the fob. I’m going to pull the door panel off and check it out but is there anywhere I can get another switch?
Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
09-13-2019 | #2 |
Re: Door Hatchback Release Switch
It may just have some corrosion on the contacts? Mirrock corvette typically has them.
09-13-2019 | #3 |
do your dome/courtesy lights work with that door open? I think they tie into that switch too, but I forget.
09-13-2019 | #4 |
I had a weird thing happen today. The interior lights did not come on. They were good because I could turn them on with the dimmer switch. The door jamb switch did work. Then after a drive, everything started to work again. Weird. Including the door hatchback release.
09-13-2019 | #5 |
Yup, if the door ajar/open switch doesn't work, the hatch release won't work either.
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 |
09-13-2019 | #6 |
After a drive you charged up the battery
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-13-2019 at 10:25 PM. |
09-14-2019 | #7 |
I have the battery on a tender so the battery is always charged. It does this wether I drive it or not, so I suspect contacts are the issue. I’m replacing the weatherstrip on the door panels so I will check it when the panel is off.
09-14-2019 | #8 |
Either contacts of the door switch for the courtesy lights or that switch is sticking
09-14-2019 | #9 |
I’m taking the door apart next week to check it out.
