Old 04-03-2007   #1
Chris H
Exclamation Cigar lighter
Hi,
Just got a Z last summer. The cigar lighter doesnt work and i wanna hook up a radar detector. Another quick question ive seen alot of different numbers and post on special things for changing the oil. What is the right amount of quarts, what type of oil and what else do i need to be aware of when changing it, plugs and wires and fuel filter were recently done i saw something about a PCV valve and throttle body cleaning anybody know about this. I know this is alot but i dont want to mess it up gotta keep this awesome car in great shape.
Chris
Chris H is offline   Reply With Quote
Old 04-05-2007   #2
Jim Nolan
Default Re: Cigar lighter
I have a '92 and when I bought mine the cigar lighter did not work either. I think that if you check you will find that your brake lights don't work. If that's the case then the fuse under the center of the dash is blown. If I remember correctly you have to remove the passenger left side kick panel to get to the fuse.
Old 04-05-2007   #3
zr-1assassin
zr-1assassin's Avatar
maybe its not working because your calling it a cigar lighter. try calling it a cigarette lighter and see what happens gotta have a little fun!
zr-1assassin is offline   Reply With Quote
Old 04-06-2007   #4
FOR OIL CHANGE INFO GO TO----
http://www.zr1netregistry.com/forum/...ead.php?t=2476
AND
http://www.zr1specialist.com/HAT%20W...comparison.htm
Old 04-08-2007   #5
IowaZR-1
IowaZR-1's Avatar
what it ready is ......the power supply for our radar detectors
IowaZR-1 is offline   Reply With Quote
Old 04-08-2007   #6
zr-1assassin
hey, where in iowa are you? are you going to b.g. this year? i ask because im in missouri
Old 04-08-2007   #7
IowaZR-1
IowaZR-1's Avatar
southeast corner of the "cornfield"....yep, going to b.g. staying at the Super 8
Old 04-09-2007   #8
zr-1assassin
i'm in the northern part of missouri, you are going through missouri correct? i am going down wed night the 3rd. if you are too,we could roll together.(whats better than seeing a zr-1 going down the road...........seeing two!)let me know when you are going and maybe we can hook up.
