Old 06-07-2019   #1
Ccmano
Ccmano's Avatar
Default Camaro 4 Piston Brembo kit
This 4 Piston Brembo kit for a late model Camaro with 13.6 inch rotors is a heck of a deal. $400.00 Almost too good to be true. Curious if anyone has had any experience fitting these calipers?
https://www.chevydirectparts.com/oem...w0LWdhcw%3D%3D
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-07-2019   #2
Karl
Karl's Avatar
Default Re: Camaro 4 Piston Brembo kit
Looks similar to this big brake upgrade.
http://www.zr1.net/forum/showthread.php?t=29748
Good luck on getting info from the person.... Didn't seem to want to disclose much to say the least.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 06-07-2019   #3
Ccmano
Ccmano's Avatar
They do look the same and are for the same year Camaro. He doesn’t go into what he did to mount them, tho apparently the do bolt up but required some slight modifications.
H
Old 06-07-2019   #4
msv
The picture that goes with that link is misleading, that is not what the kit consists of. The calipers are 4-piston, the discs are 1-piece. The calipers themselves are shared between the Camaro6 SS, C7 Z51, and some Cadillac models, just with different pad compounds and paint.
Unfortunately, the discs in that kit aren't of any use on the C4 because the centerbore is too small.
The calipers are for a 345x30mm disc, and the C7 Z51 discs will fit on the C4.
Of course a bracket would then have to be made to mount the caliper. The calipers have a 128mm spacing and on a 345mm disc the mounts are 64mm from disc centerline. The C4 caliper mounts are 130mm spacing, and ~75mm from disc centerline.
msv is offline   Reply With Quote
Old 06-07-2019   #5
Karl
Karl's Avatar
Is that price for both front brakes or just the left side?
Old 06-07-2019   #6
Ccmano
Ccmano's Avatar
Good question, saw that too. The pictures and description indicates a front set.
H
Old 06-07-2019   #7
Ccmano
Ccmano's Avatar
I suppose a machine shop could enlarge the center bores.
H
Old 06-07-2019   #8
msv
H
For sure, just a bit of a hassle to do that every time the discs need replacing.
The benefit there vs. the C7 Z51 discs though, is that the Camaro ones are 10mm deeper so wheel clearance to the caliper is easier since it doesn't overhang the wheel mounting surface as much.
Old 06-08-2019   #9
Ccmano
Ccmano's Avatar
Do you have these dimensions for C5 and C6 Z06 calipers?
H
Old 06-08-2019   #10
msv
For the C5 and C6, the hole spacing is 128mm, and the offset from disc centerline is 86mm.
The attached diagram shows what I mean by the offset dimension.
