05-30-2019 | #1 |
Service ride control light..
Rear shocks have been leaking for awhile..Picked up a good used set from a member awhile back..
Car was in for CV joints the last few days so I told my mechanic to swap out the rear shocks for me.... Service ride control light is on now... What's the steps to eliminate this? Shocks I put in seemed to be in working order... |
05-30-2019 | #2 |
Re: Service ride control light..
Same happened to me when I put in new shocks. My Wazoo brothers told me don't worry about it and just drive. The system has to relearn and when it is done the light will go off. They were correct. Can't remember how long it took but it will go off.
05-30-2019 | #3 |
Ok Charlie Thnx for the info.....
05-30-2019 | #4 |
That’s the case if the key was switched on and off 3 times without the car rolling I’m not aware of any learning after the shocks are installed I know the system will run a test and if something is out of wack the light will go on and stay on. Best thing to do is check the codes and see what it is complaining about.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
05-30-2019 | #5 | |
Correct!
05-30-2019 | #6 |
I currently have the same problem after I installed new shocks back I bought the car in 2009. It went out but It came back on in the last few weeks. I asked Gordon about it and he said tighten down the nut as they will work loose. I haven’t done it yet but I will next week.
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
05-31-2019 | #7 |
Based on my experience, when I installed a brand new set, it took a while for selective ride system to function properly and turn off the the warning linght. I think this was due to new shocks having a bit of resistance in turning the gear on top which loosened up after a while.
When gear is turning freely (as in used shock), as mentioned below, for fronts, I would check gear to planetary gear in actuator relationship. Look for crushed rubber bushing below the cup or cup being too loose. |
05-31-2019 | #8 |
Vette73... jump the pins and get your fault codes. It will be pretty straight forward after that. Until you do that, you are just guessing.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
06-04-2019 | #9 | |
If the service ride control light was on then went off, the problem, whatever it was, went away. The SRC controller is like others on the car in that after a certain amount of cycles with the fault not present, the controller turns the service light off.
06-05-2019 | #10 |
Since I was mistaken on the SRC "learning" it now came back to bite me. Now my Service Ride Control light is on!!! Shows a code 21 which is left front time out. I hope it is the small gear on top of the shock as that is a simple fix and did it a few years ago.
