05-01-2019 | #1 |
Disabling the Air Bag and Seat Belt Warning Lights
Hello all,
When I purchased my car, it came with an aftermarket steering wheel which I plan on keeping. Problem is, both the air bag and seat belt warning lights remain on. Is there a way to disable or trick the car into thinking they are there? I imagine I can remove bulbs but that seems extreme. Any help is appreciated! Thank you Tony Sent from my iPhone using ZR-1 Net Registry |
05-01-2019 | #2 |
Re: Disabling the Air Bag and Seat Belt Warning Lights
I just recently installed an aftermarket steering wheel in my 91. I had to install a 2ohm resistor. If your seat belt lights are on also I don't know much about that but am pretty sure you can get away with installing the resistor in the wiring for the clock spring and the lights should go out.
05-01-2019 | #3 |
I wouldn’t do that. You will likely disable the airbags as well. Exactly what “light” is on? InfRest? If so it’s likely it’s this very common C4 issue where the the left and right impact sensors mounted to the the frame rail have a corroded ground. Here’s how to fix it.
H http://www.zr1netregistry.com/Inform...EST-light.aspx
05-01-2019 | #4 | |
05-01-2019 | #5 | |
H
05-01-2019 | #6 |
I agree with you if he doesn't want to keep the aftermarket steering wheel. If he does then the resistor method is pretty simple. I tried pulling bulb out of dash and I don't know if it caused it or not but my sys light came on in the lcd screen. I replaced bulb and did resistor method and all has been well.
05-01-2019 | #7 |
Thanks for the replies guys, I do want to keep the aftermarket Momo wheel. Where exactly does the resistor go? Any pics or a thread of someone who did this?
Thank you, Tony Sent from my iPhone using ZR-1 Net Registry |
05-02-2019 | #8 |
There is a yellow wire that if they just cut off the clockspring behind the steering wheel. You would just connect one end of the resistor to each wire. If they actually unplugged it and pulled everything out there will be a connector behind the knee panel on the ds. You would basically put ends on the resistor and plug it into the plug. If you look up aftermarket steering wheel there are a few write ups here. I found some on corvette forum as well.
05-02-2019 | #9 | |
Thank you for this! I assume the knee panel is this center one? Just want to make sure before I start tearing things apart. I pulled the wheel to fix the horn and wasn’t looking forward to that again. Sent from my iPhone using ZR-1 Net Registry |
05-03-2019 | #10 | |
