Old 12-15-2018   #1
Subfixer
Subfixer's Avatar
Default Oil Pan Gasket R&R
Replacing the oil pan gasket requires some patience.....
Followed the service manual with the exception of removing the exhaust shields.
While the pan removal was straight forward, removing all the shields and brackets from the oil pan bolt/studs was a major PIA.
Reinstalling the drivers side shield (left rear two bolts) has taxed me for today. That top bolt that goes into the block will wait for another attempt tomorrow...……
Here's the "insides"..
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 12-15-2018   #2
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: Oil Pan Gasket R&R
When I did mine, I just bent the bracket straight and bent it back after....
You’re right, it’s a PIA.
Old 12-16-2018   #3
BigJohn
BigJohn's Avatar
You feeling better today?
