Old 12-06-2018   #1
jss06c6
Default 1990 complete antenna
Anyone have a lead on a complete 1990 antenna? The one I'm working on is badly corroded. Not sure if we can save it.
Steve
Old 12-06-2018   #2
jss06c6
Default Re: 1990 complete antenna
Steve
Can't repair this one..[ATTACH]
Old 12-06-2018   #3
I have 3, need to swap the one in my car I have another by you will need to reuse the coax of the one you have
Old 12-06-2018   #4
jss06c6
Jeff, not quite sure I understand. Are you indicating that you do have one I can buy but I will need to reuse the coax on the one I have?
Steve
Old 12-06-2018   #5
Yes Inhave one that you might need to use some of your parts to fix.. I will get pictures for you
Old 12-06-2018   #6
jss06c6
Thanks!
Old 12-07-2018   #7
Worst case scenario a 93 antenna will work with h a few wires moved around.
Old 12-07-2018   #8
jss06c6
We've ordered one of the "new" aftermarket replacements as well to see if we can make one good one out of the two!
Old 12-28-2018   #9
kjracer8699@gmail.com
I am struggling with problems on my 1992 Corvette antenna as well. On the aftermarket replacements, you mentioned in your post, do you have a part number, picture, or some type of description of what aftermarket antenna you have tried? How does it work?
kjracer8699@gmail.com is offline   Reply With Quote
Old 12-29-2018   #10
jss06c6
Just catching up.. I'll get the info in the one we ordered when I get back to my shop tomorrow. We didn't use it. Located a used one here on the registry and built a good one from the two used units.
