Old 03-08-2007   #1
SharkPilot
SharkPilot's Avatar
Default New clutch master
I'm once again fixing my red Beast.
The clutch master started leaking. I am going to replace both the master and slave. My question regards the slave. I have read about lots of them having the seal installed backwards. Is this still a problem? I'm not afraid of taking this one apart but would rather not do it if it's not necessary.
It is a genuine GM part #12509313 that I just purchased today.
As always... Thanks for the help.
SharkPilot
[CENTER][SIGPIC][/SIGPIC]
1991 ZR-1 #1135 Red/Red with both tops.
Stock except for an open topped K&N filter.[/CENTER]
SharkPilot is offline   Reply With Quote
Old 03-08-2007   #2
Jeffvette
Default Re: New clutch master
Supposidly the new ones are corrected. Call Bill and talk to him
www.zfdoc.com
Old 03-08-2007   #3
SharkPilot
SharkPilot's Avatar
Thanks Jeff, I'll give him a call tomorrow.
Did you check out the photos of the charcoal? I replaced the canister and blew out the purge line and replaced the purge valve. With two new coils and a set of wires the engine is running very well. Smooth as a... well you know.
Now I just need to get these cylinders installed.
