Old 05-23-2018   #1
TX '90 ZR1
TX '90 ZR1's Avatar
Default Fuel Pressure Bleed Off Resolved
This issue may have been previously addressed, but I did not locate it in the archives so am posting it here for reference.
My '90 was not holding fuel pressure in the system after engine shut down. First thoughts were injectors, followed by fuel pump check valves and fuel pressure regulator. All these checked OK.
I traced the leak to the plastic "Y" connector on the fuel pump/sending unit assembly. It is the connection from the two fuel pumps to the pressure outlet. Photo attached. It is the part in center of photo.
The plastic "Y" had separated a bit on the bonded seam of the outlet that went to the secondary pump. I am assuming plastic submerged in gasoline will not last forever, you think?
I did a repair to the seam, but am looking for a more permanent solution. Will advise when I come up with something.[ATTACH]z051918-01.jpg[/ATTACH]
Hope this might be of help to someone experiencing the same issue.
Kenny
1990 #442
Old 05-26-2018   #2
QB93Z
QB93Z's Avatar
Default Re: Fuel Pressure Bleed Off Resolved
I have a couple of take-out fuel pump systems. If you want an original Tee I will send it to you.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 05-26-2018   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Jim:
Sent you a PM. Thanks
Kenny
1990 #442
Old 05-28-2018   #4
Blownrunner
This would be a perfect place to install and aluminum replacement. I need to look into this.
Blownrunner is offline   Reply With Quote
Old 05-28-2018   #5
Blownrunner
https://www.industrialspec.com/shop/...-barbed-y.html
Bingo! Time for an upgrade!
Old 05-28-2018   #6
TX '90 ZR1
TX '90 ZR1's Avatar
Originally Posted by Blownrunner View Post
Yes, I have checked into these. They would probably work, but there are a couple of drawbacks.
#1- The configuration in these parts is actually a true "Y". The original is straight from outlet port to one of the fuel pump ports. The second pump port actually Y's into this straight run.
#2- This is the BIGGIE in my opinion. The fuel outlet port is designed to be used with 3/8" hose. The fuel pumps are designed to be used with 5/16" hose. Therefore, you have 1 port on the "Y" fitting for 3/8" and 2 ports for 5/16".
The pump outlets are plastic and do not have a good "barb" to grab the hose. I would be concerned that 3/8" hose could slip loose.
Just hold on before you do anything. I am working with someone that everyone here will know to build some of these fittings. Most likely aluminum and they would be a direct replacement.
Kenny
1990 #442
Old 05-28-2018   #7
Young1
Young1's Avatar
You guys are incredible. Keep the legend alive with custom made pieces is the only way to go.
Old 06-03-2018   #8
Demps
Demps's Avatar
I was searching for longer fender well screws for splash guards and stumbled here. Is nylon fuel tolerant? Don't even know the size but this site has some potentially good things for other uses.
http://www.clipsandfasteners.com/Nyl...6-p/a12927.htm
Ted
Old 06-03-2018   #9
TX '90 ZR1
TX '90 ZR1's Avatar
Ted
Ted,
I'm not sure if nylon can live in gasoline or not.
I have done a lot of looking, and the issue that I keep running into is that all the fittings readily available (or at least the ones I have found) only accomodate 1 size hose. ie: all 3 outlets are either 5/16" or 3/8". The original has 1 outlet @ 3/8" and 2 @ 5/16". Just this in itself creats correct fitment issues.
Jim is sending me an unmolested original part and I'm getting w/Carter to duplicate them. It is his call on the material, but I'm thinking probably aluminum.
As soon as I receive the original, I am meeting up w/Carter to get the ball rolling.
With all this said, it should not be too long before an accurate part will be available to replace the old plastic originals.
Will keep everybody posted.
Kenny
1990 #442
Old 06-08-2018   #10
Flyman 27
Flyman 27's Avatar
There is a brass Tee on ebay that might fit the bill. It is 5/16 x 3/8 x 5/16. It is coming from China, so it won't be a quick delivery. But maybe we should stock up on a few of these, they are cheap enough at $3.29 ea.
https://www.ebay.com/itm/Reducer-Hos...72.m2749.l2649
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
