Old 03-06-2007   #1
evl_twn
evl_twn's Avatar
Default Flushing power steering fluid
What's the best method? I just got my Z last year from the original owner, and just about all of the other maintenance issues are finished. I'd like to change/flush the PS, what's the best way to do it?
evl_twn is offline   Reply With Quote
Old 03-06-2007   #2
guinnessdood
guinnessdood's Avatar
Default Re: Flushing power steering fluid
Well...it is a pretty messy job if you want to get ALL of it out...you need to disconnect a hose underneath and drain it out...even then there will still be some in the system. I would recommend using a turkey baster to suck out as much as you can and refill it....much less mess but not a 100% fluid change either.
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 03-07-2007   #3
mbabbitt
mbabbitt's Avatar
Get an old syringe and suck out the reservoir, refill it with RedLine Power Steering Fluid, drive it for a few hours. Repeat this 3-4 times. After the 4th time, you should have fairly clean PS fluid.
Mark Babbitt
Durham, NC
1994 #444 Polo Green
"I live with FEAR everday, but sometimes she lets me instruct at HPDE's"
North Carolina State Director
mbabbitt is offline   Reply With Quote
