01-29-2018 | #1 |
DNS dreaded no start - low voltage edition
Hi everyone. My 94 has an intermittent no start condition. Always starts with a jump.
When it won’t start, the voltage meter is inevitably low, below 13 volts. The battery was new in May and I just replaced the alternator. The security light does not blink when the car won’t start. The volt meter does not dip when you try to crank the engine over. I’d be grateful from any suggestions. |
01-29-2018 | #2 | |
Re: DNS dreaded no start - low voltage edition
Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-29-2018 at 08:16 PM. |
01-30-2018 | #3 |
Makes sense. Appreciate the tip.
