07-29-2017 | #1 |
Wanted, 1991 air horn/oem cold air box, air filter box assembly.
I am looking for a stock ZR-1 cold air box/filter assemble for my 1991 Z. Recent purchase, present parts are warped and non-functional. Any one want a K&N air filter? Dan
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
07-29-2017 | #2 |
Re: Wanted, 1991 air horn/oem cold air box, air filter box assembly.
If the neck of the housing is split along the seams, that can be repaired with a strong plastic epoxy from your local parts store. You'll need some strong clams to ensure a tight seal.
07-29-2017 | #3 |
I am going to revert back to the OEM paper filters. So they should fit ok, but I will look it over carefully.
07-29-2017 | #4 |
I have some extras but it will be Monday before I can get pictures to you. PM me your email address if you are interested.
07-29-2017 | #5 | |
07-29-2017 | #6 |
I love that Apple autocorrect. West coast technical expertise!
08-03-2017 | #7 |
Jeff from Bartlett stopped by and helped me out with my Airbox problem.
I have an aftermarket airbox with the wrong fasteners. After a trip to ACE Hardware, all is well and working like it should. Thank you for the support. Dan
