Old 03-25-2016   #1
Racinfan83
Default Need Help With a Couple Things - Trans Removal
Working slow but steady on my baptism of Z trans removal.. Ran into a couple things today I need to ask about before I proceed..
Can't get the clutch slave cylinder to come out the hole. It gets to this point in the pic and won't go any further???
AND - how do I get the shifter boot out? I took off the 4 nuts on the top and the plate is loose. Can't get the boot to move?
And does this need to come off? If so - what is it and how do you get it off?
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 03-25-2016   #2
Default Re: Need Help With a Couple Things - Trans Removal
I think there is a boot on the cylinder that might be stuck in the hole but it should pull out of the hole. The top shifter boot might have some sealant holding it in place but once the 4 bolts were removed the boot will lift off the shifter.
Old 03-26-2016   #3
Jagdpanzer
Jagdpanzer's Avatar
The slave should pull out. Force your will on it.
Same with the rubber tunnel boot. Peels off around the tunnel base. Remove the tie raps that secure the transmission boot and peel back the forward end to expose the shift link retaining pin.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-26-2016   #4
Racinfan83
Ok thanks! Didn't want to tear something up with brute force if there was a trick to it...
