Old 03-19-2016   #1
secondchance
Default O2 sensors
After having gone through a head gasket failure/rebuild, I am thinking of replacing O2 sensors before taking fuel ratio readings at 1,000 rpm intervals. and having Marc touch up the PROM chip.
Any suggestion/preference for O2 sensors? Is this another component I have to watch for and avoid "made in China"?
Old 03-19-2016   #2
Default Re: O2 sensors
............ Any suggestion/preference for O2 sensors? Is this another component I have to watch for and avoid "made in China"?
Avoiding Made in China may be harder than expected. You can rule out ACDelco, Standard Motor Products, Denso, Delphi, etc.
Old 03-19-2016   #3
Scrrem
Scrrem's Avatar
Let me know what you find. I'm going to change mine as well.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-19-2016   #4
Hib Halverson
For about the last 15 years, I've used Denso O2Ses in my LT5. In fact, I have Denso O2s in most of our cars. I feel they work better and longer than either Bosch or Delpi sensors.
Also, on using O2Ses to take "fuel ratio" readings...keep in mind that you cannot use narrow-band sensor readings to measure how the system is fueling in PE because narrow band sensors are not accurate at any AFR other than stoichiometric. To test power enrichment at WOT, you need a wideband.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-20-2016   #5
secondchance
Understood. I'll discuss WOT enrichment strategy with Marc.
Thanks!
Old 03-20-2016   #6
Unfortunately, we don't have left and right bank tables for WOT tuning so it will optimize one side (the one w the WBO2)and not the other. The PE fuel mods are done in 500rpm increments.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-20-2016   #7
Hib Halverson
Log some data then look at the LTFT (block-learn) values for both banks.
Put the wideband in the side which runs the more lean. Do your PE cal. You'll know that the other side is never going to be more lean.
Old 03-21-2016   #8
I replaced mine with Bosch I think. I've got a question that just boggles the mind,why are Chinese products just crap? I would have no problem buying Chinese parts if they weren't crap but jeez,it's nothing but total crap. Now,back on topic,can't remember but one of the 02 plugs is extremely difficult to get to and plug in.
Old 03-23-2016   #9
secondchance
Received a pair of Bosch sensors. It says "assembled in USA". What does that mean? Still better than "made in China"?
Old 03-23-2016   #10
it means get that car on the dyno.....
