Old 03-06-2016   #1
aafc
aafc's Avatar
Default New exhaust system with 3 "cutouts
While my ECM and chip are out being tested, i removed my power effects
exhaust system. Then installed a stock LT1 system with factory mufflers
with H pipe and added 3" cutouts. I have not tried it as the ECM and chip
won't be tested until Monday or later this week.
http://www.zr1.net/forum/picture.php...pictureid=3051
http://www.zr1.net/forum/picture.php...pictureid=3052
http://www.zr1.net/forum/picture.php...pictureid=3053
aafc is offline   Reply With Quote
Old 03-06-2016   #2
Kevin
Kevin's Avatar
Default Re: New exhaust system with 3 "cutouts
if i lived closer I'd see what you wanted for the PE system
Old 03-26-2016   #3
Johnny5
any sound cllip???????
Johnny5 is offline   Reply With Quote
Old 03-26-2016   #4
That's what I did with my '95. After testing probably a half dozen systems over 20 years on two cars, and mostly using Corsas, I went back to a stock system with electric QTP cutouts. At first I placed them where you did and removed the spare carrier. Then decided I wanted my spare so had Marc H move them to right in front of the mufflers. Have a rocker switch hidden under the carpet on the passenger side of the console. Here are a couple of pix--Bob
Old 03-26-2016   #5
lisounds
lisounds's Avatar
interesting...
does a stock LT-1 Exhaust system bolt right up?
1995 ZR-1 Red / BLACK
NCRS NATIONAL WINNER DAVE HILL AWARD
TOP FLIGHT & PV AWARDS
Currently in my Stable:
1978 PACE CAR L-82 4SPD "Triple Crown Winner"
1979 TRANS AM Bandit Edition 400 4 spd WS6 Y84 W72
1981 PORSCHE 930 TURBO
1995 ZR1 Red / Black
2004 Z06 Yellow / Black
2010 C6 Grand Sport Convertible Red/Black
lisounds is offline   Reply With Quote
Old 03-26-2016   #6
aafc
aafc's Avatar
I do not have a sound clip of the new system with cutouts,working on it.
The stock LT1 exhaust will work just get one that was used on a manual
transmission. Ii should have all the parts you need. Not sure if a lt1
system used on an auto transmission will work.
When i made my system i only needed the exhaust pipes from the resonator
back. My system uses Jeal headers no cats to 2 3/4 in H-pipe to the stock
2 5/8 in lt1 system. Cut outs are open/closed with a key fob.
my LT1 system came off a 1995 car.
Old 03-28-2016   #7
youngrm
I have a video including sound of a 3" exhaust with qtp's if someone wants to host it
Ry
youngrm is offline   Reply With Quote
Old 03-29-2016   #8
C4Ray
Bob had an awesome ZR1 set-up with his Cut Outs. OP, I'm curious why not go with Corsa then add Cut Outs?
C4Ray is offline   Reply With Quote
Old 03-29-2016   #9
aafc
aafc's Avatar
C4RAY,
I brought my car in April 1994 and install the power effects system
in AUG. 1997. Never tried any other system, removed PE system Feb.
2016 and installed the LT1 from a 1995 C4. Now my exhaust system
consists JEAL headers, 2 3/4 in H pipe connected to 2 5/8 in LT1 mufflers
with the 3in cutouts. To sort of hide the cutouts i painted the parts with
high temp header paint. The PE system (resonator rear pipe and mufflers)
are for sale. Prefer local sale, do not know what shipping would be.
1990 white/black #2546
one of a few auto (4l80E) eq ZR-1's
