Old 02-15-2016   #1
KJL
Default Has anyone removed the rear diff....
I am looking to upgrade my rear gears to 4.1 and possibly the flywheel to a lighter weight aluminum unit. I don't have a lift but have done this work on my 1972 vette up on jack stands. Is it possible to do this with a C4? I know the transmission is a lot heavier than my TKO5 speed.
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 02-15-2016   #2
Default Re: Has anyone removed the rear diff....
Yes, you can remove the complete batwing assembly or just the pumpkin.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-15-2016   #3
RussMcB
KJL, send me a heads up when you think you'll tackle it. I'll come over and lend a hand if you'd like and if I'm free.
I almost tackled that job (rear gear change) a few months ago, researched it a little bit, but didn't follow through (I've since changed my mind about changing gears). Soon on my to-do list is to replace my rear leaf spring, so I'll probably be removing some of the same bolts as you.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 02-15-2016   #4
KJL
Hey Russ, haha, just sent you a PM. Thanks for the info. Thinking about doing doing a gear change... although I have rebuilt a rear diff before, likely send to Marc H. for the rebuild.
Not sure what I want to do with the 92. Nice stock car but damn, this is the last year I need to worry about emissions... can do what ever I want.....
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 02-15-2016   #5
KJL
Hey Steve-
It has been awhile, I hope all is well with you. I just finished most of the upgrade to my 72 but having some tuning issues. The car has been sitting at the builders garage since Jan 1st. No sooner do I get done messing with one, I get the urge to work on another. I fixed all the little things that were wrong with the 92, third brake light, head light gears, bad rear audio amps (I am now an expert at replacing the caps myself). , tightened the oil pan bolts...man were they lose... no more leak, new radiator overflow tank and chased down some vacuum leaks and flow master exhaust (thanks to you) now she is almost as good as new.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 02-15-2016   #6
ZRXMAX
ZRXMAX's Avatar
Changing the rear spring is easy and can be done in a half hour or less. Changing the rear end will take some time and is rather awkward without the right tools and support.
I do mine on the garage floor and use a floor jack fitted with a lifting bracket I made for the diff. I take the batwing and all for the simple fact I don't like dealing gear lube until the unit is on the bench.
Getting a set of Beam Plates from Bill B will make reinstalling the unit a bit easier.
I also suggest you support the transmission where it is at and remove the C beam so the shifter boot stays intact and in place so you don't have to re seal it later.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 02-15-2016   #7
KJL
If I take all that off, wouldn't that be a good time to change out the flywheel? Don't know what is involved with that. I assume the exhaust must be removed from the cats back? Has anyone rebuilt the rear diff themselves? I did for my 72, I recall needing some hefty tools for torquing the pinion nut etc.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 02-18-2016   #8
Good to hear from ya, hope all is well. Flowmaster my not be the best flowing exhaust but I think it is one of the best sounding. I put mine on the 93 when I changed to Corsa on the 91. Keep in touch.
Steve
1990 Red/Red #1473
Old 02-19-2016   #9
I've dropped both trans and diff from my C4's. The diff is easier than the trans because of the weight and the space.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-19-2016   #10
KJL
Thinking that if I am going to drop the diff, upgrade beam plates. I may as well do the clutch and upgrade the flywheel while I am at it. I just know how heavy my TKO 600 was. All I used was a Harbor Freight scissors jack laying on my back.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
