Old 01-16-2016   #1
Vette73
Default Slight hesitation at 2,000-2,500 RPM with power key on
Just had the plenum and injector housings ported...
If I get into the throttle hard the car has a slight stumble at 2,500 RPM around..
I really can't classify it as a hesitation, it's like the car feels like it shuts off for a split second than it catches.......If I'm driving " normal" it really doesn't do it, just when I really lean into the gas...
Does not do it at all when the power key is turned off....Other than that the car has plenty of power and does not stumble at all at high RPM just down low like I explained...
Vette73 is offline   Reply With Quote
Old 01-16-2016   #2
efnfast
Default Re: Slight hesitation at 2,000-2,500 RPM with power key on
Di d you have the chip reprogrammed after the porting?
Old 01-16-2016   #3
Vette73
Yes....I called Marc and sent him the chip...
He added more fuel to it and raised the redline to 7400 rpm..
Old 01-17-2016   #4
Hib Halverson
Have you logged data when the problem occurs?
If so what are the O2s doing when that stumble happens?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-17-2016   #5
Vette73
Hey Hib....
I guess I can run this by my mechanic...I'm not to familiar with diagnosing this..
Very new to the LT-5.....Allthough I did all the labor except for the porting when it came to the plenum and injector housings,also swapped out the coils and changed the starter....My injectors are aftermarket Accels and like I said it only does this with full power key on..
How do I check the 02s ?
Thank you..
Old 01-17-2016   #6
Hib Halverson
Originally Posted by Vette73 View Post
Hey Hib....
(snip)
(snip)
With a scan tester which can data log.
Hib Halverson
Technical Writer
Old 01-21-2016   #7
tnova
Same problem with my '91. Have ported plenum and aluminum flywheel as main driver for Marc's chip. Been all through the common causes; fuel pumps, secondary activation, secondary FI relay, new 02 sensors, new coils, etc., etc. Will be watching your findings.
tnova is offline   Reply With Quote
Old 01-21-2016   #8
George Maz
Would a Tech 1A scan tool be of service for you? If so, let me know and I'll let you borrow it. Astoria George & Me saw a pair of these 1A's selling cheap, and scooped them both.
Glad to hear you're driving the car, I just put mine away now that they've begun salting the roads.
1990 ZR-1 #1587
1990 ZR-1 #1727
George Maz is offline   Reply With Quote
Old 01-21-2016   #9
Vette73
Hey George thanks so much....
I'm going to run it by my guy first and see what he says....I think my driving days may be over for a while with this impending storm coming..
Stay safe...Will be in touch..
John ...
Old 02-01-2016   #10
Vette73
Yes Marc said to check the fuel pressure....I see you changed out your fuel pumps I presume.....Also asked me if my vacuum pump turns off after a few seconds with the key on, not the engine on....
I will run this by my guy soon and post any findings...
