Old 12-14-2015   #1
aafc
aafc's Avatar
Default stage one cam specs
OK,
So i'am sitting here 12 days after having my right shoulder replaced. and
someone asked me what are my cam specs on my 368 cu in stage one
cam motor ( 1990 ). So how do if out or can someone tell me.
As far as my shoulder goes, during real good I go in tomorrow for first
PT evaluation. The only bad thing is i can't drive the ZR-1 for 3 weeks or more.
thanks,
1990 white/black auto ( 4l80E ) eq ZR-1
aafc is offline   Reply With Quote
Old 12-14-2015   #2
HAWAIIZR-1's Avatar
Default Re: stage one cam specs
Originally Posted by aafc View Post
OK,
thanks,
John,
I guess it depends on who designed the Stage I cams you have. If South Georgia Corvette (Aaron Scott), it will be: lift .420, duration
230 degrees at .050 for both intake and exhaust cams
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 12-14-2015   #3
aafc
aafc's Avatar
Craig,
thanks for the information , The motor was built by Arron Scott @ SGC.
back in Jan 2009 .I cannot find my build sheet for the information. The
6-speed was replaced with an auto back in Aug 2004.She has run the best of 11.58 @ 120.00 in the 1/4 mile.
Thank you
1990 white/black #2546
one of a few auto ( 4l80E ) eq. ZR-1's
Old 12-15-2015   #4
HAWAIIZR-1's Avatar
You're welcome John. I've always admired that car of yours. I have the same cams are the only reason I knew the specs. Regards, Craig
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
