Old 12-08-2015   #1
edram454
edram454's Avatar
Default Oil Sensors
anybody ever have a oil sensor leak fresh oil?? in the assembly manual it shows an exploded picture of the oil assembly and it shows 2 sensors, one on top and one under and to the right of the oil filter. there is a third sensor that talks to the computer. I think the top sensor is for your oil gauge and the other is oil temp and the third one not in the exploded picture is the one that is leaking. I was smelling fresh oil on the right side of my engine and I saw some on the right frame rails and under the oil filter.. this car was moving for some time at 70 mph so the oil leaks and runs down the frame rails and everything else. all this is on the right side of the engine. apparently, this sensor is very hard to get to and requires the engine to be tilted to have the space to change the sensor. I have not found one technical drawing that shows that third sensor. ideas??
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 12-08-2015   #2
Default Re: Oil Sensors
ed ramos #3028
Engine Oil Pressure/Temperature Sensors
Oil Filter Adapter Sensors ..............................................Oil Filter Adapter Ports and Sensors
Old 12-08-2015   #3
edram454
edram454's Avatar
Mr. Dynamite you are a monster of information. Thank you for this wonderful pics. Its guys like you that make this forum extremely valuable.
Thanks!!
ed ramso #3028
EDRAM454
Old 12-09-2015   #4
Mr. Dynomite you are a monster of information. Thank you for this wonderful pics. Its guys like you that make this forum extremely valuable.
Thanks!!
ed ramso #3028
Thank You Sir........
Any time from Cliff #3032 (four cars behind you on Assembly Line in 1990)
Old 12-09-2015   #5
Thanks!!
ed ramso #3028
I agree! Personally, ah doan need no mo "T" shirts... I gladly pay for Cliff's SOLUTIONS page and the rest of the forum support!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 12-10-2015   #6
edram454
edram454's Avatar
Yes Sir, yours is the last one for 1990!
ed ramos #3028
EDRAM454
