09-05-2015 | #1 |
Tachometer
My tachometer reads approximately 48% high based upon the AC display verification.
09-05-2015 | #2 | |
Re: Tachometer
I discovered mine when actually trying to confirm a rear axle ratio that would have explained my tach variance but this was on a car that wasn't thought to be modified. I checked mine vs. a Tech1 scanner rather than the C68 display. Mine is repaired and correct but NOT by me. Last edited by WVZR-1; 09-05-2015 at 11:49 AM. |
09-05-2015 | #3 |
Re: Tachometer
Easy way ? Take the lens off then gently pull the sweep off . Then read set it and push the sweep back on.
09-05-2015 | #4 |
Re: Tachometer
Not sure what you mean by pulling the sweep.
09-05-2015 | #5 |
Re: Tachometer
OK, I am guessing by "sweep" you are referring to the tach needle?
09-05-2015 | #6 |
Re: Tachometer
09-05-2015 | #7 |
Re: Tachometer
Sweep = Tach needle.
09-06-2015 | #8 | |
Re: Tachometer
The error is a % (of rpm) error. In short, re-positioning the needle to read accurately only works at one rpm value. the same % error will result above or below that "set" rpm.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 09-08-2015 at 10:53 AM. |
09-07-2015 | #9 |
Re: Tachometer
09-07-2015 | #10 |
Re: Tachometer
Yea. Who knew these LT5's would get up to 8,000 RPMs without hitting the rev limiter.
