Old 11-16-2014   #1
BigIke
Default First Oil Change
Got me some NAPA Gold 1324 filters and was looking at oil.
Was looking at the Mobil 1 chart for zinc level and 0W-40 look like the winner in Zinc content. It's also only35$ per 5 qts, anybody out there think this is a bad decision?
I'm in Houston TX...
<img style="display: none; position: absolute; top: 0px; left: 0px; width: 32px; height: 32px; z-index: 2147483647;" id="firefoxsddsinfoimg"><img style="display: none; position: absolute; top: 0px; left: 0px; width: 32px; height: 32px; z-index: 2147483647;" id="firefoxsddsarrowimg"><img style="display: none; position: absolute; top: 0px; left: 0px; width: 32px; height: 32px; z-index: 2147483647;" id="firefoxsddsinfoimg"><img style="display: none; position: absolute; top: 0px; left: 0px; width: 32px; height: 32px; z-index: 2147483647;" id="firefoxsddsarrowimg">
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
Old 11-16-2014   #2
secondchance
Default Re: First Oil Change
I'm not so sure about "0". I think the factory spec was 5-30. "High mileage" versions of Mobil 1 have high Zn and phosphate levels.
Old 11-16-2014   #3
diamond zr1
I personally would never run a zero-forty oil in an Lt5/while you may feel it has more zinc,I do not believe it is the right weight for these older engines// try a 10/30 or 10/40 oil amzoil//or go with the amsoil Zrod in 10/30 or even 20/50 in hot weather/high performance applications///they are high zinc //give Corey a call at Hendersen performance
diamond zr1 is offline   Reply With Quote
Old 11-16-2014   #4
Billy Mild
Run the High Mileage Mobil 1. I use 10w-30 High Mileage. So far so good.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 11-16-2014   #5
BigIke
Ok, looked at the chart and the High Mileage has all the zinc . Saw somewhere that the Extended Performance had the most Zinc (it's what plants crave). Need to scroll through the rest of the spec sheet next time!
Old 11-17-2014   #6
mike100
I mix 3 qts of the 10w-30 Z-Rod high additive oil with a 5qt jug of modern 10w-30 Mobil1. pretty much hits the ppm blend that was being sold in the 90's and saves a little since the cost of running pure z-rod amsoil is prohibitive. (and probably unnecessary to run that much additive).
Old 11-17-2014   #7
Here is a link to Marc Haibeck's article on oil suitability. Worth a read.
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
--Bob
Old 11-17-2014   #8
I use Castrol GTX Diesel 15W-40. Works great. Been using it with stock and re-ground cams for 3 years now.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-17-2014   #9
Old 11-17-2014   #10
Dime
I've run mobile 1 high mileage 10w-30. No problems that I can tell. Marc says the high mileage 10w-30 has ample amounts of zinc. Back to running amsoil now.
[B][U]1991 No. 519[/U][/B]
Dime is offline   Reply With Quote
