10-02-2014 | #1 |
Power steering line routing
Anyone have a pic of the Power steering line routing on a 91 or later ZR-1, trying to put the lines in the 91.....referenced my 1990 and its a totally different hose setup
HELP!
10-02-2014 | #2 | |
Re: Power steering line routing
P.
10-02-2014 | #3 |
This is the high pressure hose similar to my 90
After searching through a few things, the hose on the right is what was on the car...the PS failure was apparently due to hose rub
10-02-2014 | #4 |
I believe the hose that was on the car is a 93-95 hose as is the low pressure hose to the cooler. The hose on the car goes under the sway bar where the 90 goes over.
10-02-2014 | #5 |
Now I need to know the orientation of the upper hose.....on the 90 the low pressure hose is on the bottom and the high loops over the top.
Anyone know if this is correct?
10-02-2014 | #6 |
10-02-2014 | #7 |
'90 and '91 PS pressure hose is the same. There's a different part number for '92+ cars.
The return side is the same all model years. In this buyers guide a 71777 is '92+ part and 71778 is the '90 & '91 part: http://www.plews-edelmann.com/pressure-hoses/ Click the part # for images. Last edited by WVZR-1; 10-02-2014 at 05:59 PM. |
10-02-2014 | #8 |
Hope this helps off on 91. not an easy pic to get! If not from the right angle let me know I'll try again.
10-02-2014 | #9 |
hmmm....my 90 is totally different than those....and this hose set up seems to be off of a 93-95. Odd
Thanks Steve & WV
10-02-2014 | #10 |
