Old 08-31-2014   #1
BigIke
Default Few issues with my Z
Idle - It idles between 1.3k and 3k... Hunts pretty bad. I've replaced the IAC after finding the threads stripped, cleaned it all up in the TB also, no change. I've sprayed Carb cleaner around the vacuum hoses, no increase in Idle.
Tach - Is it possible for the LT5 to go 8k RPM? Damn thing feels like it's pulling hard still. Anyone have tach error issues?
The other issues are the service FX3 and a bad TPS... I'll check the codes for the FX3 and replace the bad TPS.
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
Old 08-31-2014   #2
Kevin
Kevin's Avatar
Default Re: Few issues with my Z
it's possible for the lt5 to go to 8k but you're going to need to have the rev limiter removed.
Old 08-31-2014   #3
BigIke
Going to have to install a temporary tach to make sure. I don't want to spin over 7. But it does seem to be pulling still
Old 08-31-2014   #4
Hog
IIRC the stock rev limiter is set of 7200rpm. If its still pulling then you havent hit it then. If GM thought that engine damage would result, they would have set the limiter lower than 7200rpm.
peace
Paul
Old 08-31-2014   #5
BigIke
Ok... 7K RPM in 1st gear with stock gearing what should the RPM be?
Old 09-01-2014   #6
Default Vehicle Speed in First Gear
I think you are asking mph in first gear.
First gear - 2.68
Differential - 3.45
Tires - 315x17x35
57.82 mph at 7,000 engine rpm in first gear depending a bit on tire loaded radius (315x17x35 tires).
Tech Info - ZR1 Differential Gearing and Vehicle Speed Calculations
Old 09-01-2014   #7
BigIke
Awesome... Guess I'll have to drive the car first thing tomorrow... Darn...
My wife is already getting sick of me taking one of our 2 girls in the Vette and her having to take the Diesel or Magnum... LOL
I wish I'd known how cool it was to own and drive a vette... I would have picked up the 89 DRM 383 for 8k 5 years ago!
Better than any of my SRT10's, the SRT8... 9 second stang... anything! I'm thinking about selling the LS Juan Camaro and buying a LT1 Vette as my Oilfield car...
The car since 02 has had 8k miles put on it, in 4 days I've managed 600 miles!
LOVE!
Old 09-01-2014   #8
Pete
Pete's Avatar
Most stock techs are off.
If you have stock chip/program in it, then just keep your foot in it till you hit rev limiter which is set at 7170.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-01-2014   #9
BigIke
Lol, I have no idea what's in this car... To me it is quick, but not as quick as the magnum.. I think I is stock with Borla exhaust. I will be with removing the resonator and adding an x pipe... I think
Old 09-01-2014   #10
Sorry but doesn't your ZR have the wrong rear end cap on it?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
