Old 08-26-2014   #1
Harvie
Default Thread size on throttle cable clip bolts?
My factory cataloge calls for a 4.2 X1.2 X .8 bolts(?) and I am at a loss to what size that might be.
These bolts hold the clamps that keep the throttle cables on the top of the plenum and the cover over the end by the throttle body.
I lost one of the nuts (they are 4mm X.75) and all 3 little bolts and need to get new ones and tap out the holes.
Anyone have the correct bottom tap size? (All I have is 4mm X.70 and .75)
I will go up to 5MM if it is a real bastard size and just get 5mm torx button head bolts.
Harvie is offline   Reply With Quote
Old 08-26-2014   #2
Kevin
Kevin's Avatar
Default Re: Thread size on throttle cable clip bolts?
david johson may have some
Old 08-26-2014   #3
Z06scentair
Z06scentair's Avatar
pn 11544501
Jerrys Gaskets has them
Brad
Z06scentair is offline   Reply With Quote
Old 08-26-2014   #4
Harvie
Originally Posted by Z06scentair View Post
pn 11544501
Brad
yup that is the number in the parts manual, u know the tap size?
Charter Member (since the 91) of the 1ST ZR1 Registry
1st vet $157.59. mo for 3 years new
2nd new 1 check & STILL eating funds years later
[-X show poodles & trailer queens :-({|=
Fast and fun not pretty in pink.
Old 08-26-2014   #5
Z06scentair
No need for a tap......those screws are self-tapping.
Just installed one last week!
Brad
Old 08-26-2014   #6
Harvie
Brad
Yes I see that. I have those and thought it was a mistake, I will just tap and stud all 3 of them.
Removable self tapping fastners in aluminum is not a good practice.
Old 08-26-2014   #7
Z06scentair
.8 pitch is only available in a 5mm tap.
4.2mm would be the drill/hole size required for a 5mm
To me it looks like you will have no option but a 5mm tap.
Old 08-26-2014   #8
Harvie
4mm X.7 set screws into newly tapped holes, then glued in with Devcon will do just fine. Then all nuts will them be 4mm X.7 holding everything...much more better =D>
Old 08-27-2014   #9
Z06scentair
Devcon SS putty...used it once to seal porosity in a SS WGSR to seal the oil in. Klubersynth 6-460 food grade lubricant.
That Devcon Putty was sure expensive!
Old 08-27-2014   #10
Harvie
I fixed them for good cost less than $2.00 total. 4MMX.7 all the way around.
I am a stud/nut guy where ever possible. Now all throttle cable fasteners are the same and wrenched the same 7MM nut driver...they are now stronger, way less expensive, and lower cost/easier to maintain.
Anyone want a complete set? I have one spare complete set just send me 5 bucks and I will mail them to you in a bubble envelope. VRS 3 X 4.75 plus postage for the self tapping .
