08-21-2014 | #1 |
Help identifying parts
On my last trip to the mechanic, he pointed out a couple of things under the hood that he suggested I follow up on. One was that he noticed I'm missing a cover of sorts. I've circled it in red below. Does anyone know what this is called and where I could get one?
He also had to replace the bolt below with one that's different but had the same thread. Does anyone know where I can get the right bolt? Thanks.
1991 ZR-1 #405 (white/black with blue pin stripes) |
08-21-2014 | #2 |
Re: Help identifying parts
You need the two nuts and one screw for the throttle body cover as well, I can't recall the official name but I doubt I have one of these, I might but doubt it. Check jerrysgaskets.com
And ebay as well. That bolt someone has one . Jerry should
08-22-2014 | #3 |
Does one of these look like the correct bolt?
1) Bolt, MAP Sensor to Bracket, NEW 90~95 [6.5B] 2) Bolt, MAP Sensor Brkt to Plenum, NEW,90~95 [6.5A] Thanks.
08-22-2014 | #4 | |
bracket to plenum bolt. |
08-22-2014 | #5 |
Yep the small one is the one you need.
08-23-2014 | #6 |
I replaced my map sensor bracket bolts with flange head 10mm bolts. Way easier than finding a torx bit and then trying not to drop the slippery bugger (which is probably the reason you have different hardware now-no biggie).
08-27-2014 | #7 |
Actually, while working on the car, the mechanic just happened to notice that original bolt was either broken or about to break, so he replaced it with the only bolt he had available with the same thread.
08-27-2014 | #8 |
Thanks! It never ceases to surprise me the knowledge on this forum!
08-27-2014 | #9 |
Jerry confirmed he didn't carry the cover. I found and ordered a NOS cover at White Racing Products. (Ouch, it's $$$!) They didn't carry the nuts and screw. Jerry's out of town this week. Will check with him to see if he has the nuts and screw next week. In the meantime, if anyone knows the right nuts and screw, would be appreciated.
08-28-2014 | #10 | |
The nuts are M4 X 0.7 with a flange, the screw is a self tapping M4.2 X 1.4 x 8 with a torx pan head. I'd think there's no rush so wait for Jerry or just place the order on-line and I believe the store is being "attended to"! |
