Old 05-05-2014   #1
zr-1.R1
Default CORVETTE C4 AIR CLEANER
Good evening everyone, can you help me?
I have on my Z , AIR CLEANER damaged, near the steel band.
c4 standard pieces of them are compatible?
I put a picture
zr-1.R1 is offline   Reply With Quote
Old 05-05-2014   #2
Tony Davila
Tony Davila's Avatar
Default Re: CORVETTE C4 AIR CLEANER
Yes
Tony Davila is offline   Reply With Quote
Old 05-05-2014   #3
zr-1.R1
ok, thank you.
when you pull the strap, there is a ring metal inside, not to do it crush?
Old 05-06-2014   #4
Tony Davila
Originally Posted by zr-1.R1 View Post
ok, thank you.
Take a picture if you can, not really sure what you are talking about.
Old 05-06-2014   #5
zr-1.R1
ok
Old 05-06-2014   #6
ok
zr-1,
Se voi spiegare in Italiano podarsi capisco io.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-08-2014   #7
zr-1.R1
ok perfect.
quando tiro la fascetta in metallo nell'accoppiamento tra i due pezzi , la parte interna si piega e si rompe .
di serie non è presente , un'anello di ferro per non farla schiacciare ?
Old 05-08-2014   #8
ok perfect.
English :
When I pull the metal strip in the coupling between the two pieces, the inside bends and breaks.
series is not present, a ring of iron to keep it from crushing?
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-08-2014   #9
zr-1.R1
when I pull the metal strip in the coupling between the two pieces, the inside bends and breaks.
I wrote in Italian, at the request of xfirez51, I apologize to other members of the forum.
xfirez51 have Italian origins?
Old 05-08-2014   #10
Apology not needed at all. XfireZ51 (Dominic) and I are both of Itallian origin.
Frank Urbo.
